Briggs & Stratton Model "8"
6 replies to this topic
#1 KC9KAS ONLINE
KC9KAS
  • 5,202 Thanks
  • 4,585 posts
Posted April 14, 2017 - 06:56 AM
I have a B&S Model 8 on a Bolens Versamatic.
The governor control linkage to the carb is missing.
Does anyone have any photos and/or the linkage for this?
I saw (in a parts breakdown) what appears to be a very short piece of rod wit a "Z" bend on each end. I do not know if this is what I need or what the length of it is.
Any help is greatly appreciated!
I did get it running!!
#2 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted April 14, 2017 - 07:38 AM
A pic of what your dealing with would be helpful.
#3 jabelman OFFLINE
jabelman
  • 1,991 Thanks
  • 1,466 posts
Posted April 14, 2017 - 07:52 AM
one of these, let me know and I will send a better pic
  • boyscout862 and Newpaws493 have said thanks
#4 jimmy G ONLINE
jimmy G
  • 1,018 Thanks
  • 678 posts
Posted April 14, 2017 - 09:15 AM
Their was 2 model 8's,early and late,53-54 being the change over(if I'm remember'n right),I believe I have both for pics just need to know which one,older looks similar to the N,newer looks similar to 5s-6s
#5 KC9KAS ONLINE
KC9KAS
  • 5,202 Thanks
  • 4,585 posts
Posted April 14, 2017 - 10:35 AM
In this photo, FIG 60......The small circle shows the throttle lever, spring and the short rod I am looking for..My throttle lever only has 2 holes...one for the spring, and 1 for the governor rod.
I have disassembled the carb and am soaking it in carb cleaner...The float and float needle were stuck big time.
Now I need some gaskets too!
#6 EricFromPa ONLINE
EricFromPa
  • 3,224 Thanks
  • 2,907 posts
Posted April 14, 2017 - 02:04 PM
Depending on the year of the engine they had Airvain or Mechanical governor. I had to order a couple for 2 model Ns and 1 model 8.
Briggs parts numbers.
For Mechanical governor Briggs part # 26548
https://www.smalleng...n-original-oem/
For Air Vane governor Briggs part # 26391
PM these fellas they may have a both.
http://gardentractor.../user/945-bhts/
http://gardentractor.../7-bolens-1000/
Air vane governor linkage looks like this.
Edited by EricFromPa, April 14, 2017 - 02:08 PM.
  • Bolens 1000 and Newpaws493 have said thanks
#7 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,951 posts
Posted April 14, 2017 - 03:51 PM
Sorry i'm late to this, the above parts will fit your machine thats how all mine are setup.
I may have them instock or if I need to order B&S is only 1-2 days away
