Been thinking
4 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,321 Thanks
  • 2,984 posts
Posted April 12, 2017 - 10:00 PM
Valves are not leaking now on the briggs and the only thing else I replaced was the piston and the rings which I used cheap ebay stuff.
Since it didn't do the bogging down under a load before the rebuild it leads me to believe the rings are the issue. Showing 80 psi on compression and I didn't really hear a leak with with leakdown tester. I didn't do a full teardown so the timing is still the same as it was before the rebuild.
  • 637Yeoman said thank you
#2 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted April 12, 2017 - 10:24 PM
Oh thats what im smelling then, haha im just pickin on you, got to have a little fun sometimes in a world that can be too serious, anyway, rings would be my guess, its never a good idea to pick the cheap way out, even though sometimes thats the only way you can go, i would suggest new rings.
Maybe that cheap chinese steel gets a little janky when hot?
But not when its cold.
Best of luck, Luke
  • bbuckler said thank you
#3 DougT ONLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted April 13, 2017 - 05:14 PM
I would suspect either you don't have the governor set right or you've got a carb problem.
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted April 13, 2017 - 05:17 PM
Carb or ignition problem. IMO
#5 bbuckler ONLINE
bbuckler
  • 3,321 Thanks
  • 2,984 posts
Posted April 13, 2017 - 07:05 PM
Ignition. On my way back to the barn I lose spark and found the flywheel key was sheared. I replaced it but still have no spark.
