gt/lgt 18h reverses by default
10 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 157 Thanks
  • 166 posts
Posted April 12, 2017 - 02:54 PM
Right now I need to keep my foot on forwards a little just to keep it still, if I take my foot off the pedal it goes slightly into reverse.  Is this as simple as a missing spring or something under the pedal?  There's a hole right there and nothing in it:
Or do I need to adjust whatever this is called?
#2 propane1 ONLINE
propane1
  • 9,741 Thanks
  • 4,517 posts
Posted April 12, 2017 - 03:16 PM
Should be an adjustment some where. My lgt 165s and my yt16h fords have adjustments.
Noel
#3 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted April 12, 2017 - 04:00 PM
Find a manual!  Mosty hydros have some cams and or lever combinations to have the pedal return to Nuetral and sort of lock in place. If new enough, the brake should also make it go into neutral when applied.  A good cleaning of these mechanisms and when freed up a good lubing is best. Many have a spring to assist these operations, but more on linkage than on the actual pedal. As noted, a manual for adjust and maybe a parts manual for ID'ing the parts used in the system. Might be some of those right here if you look.
#4 Mustard Tiger ONLINE
Mustard Tiger
  • 157 Thanks
  • 166 posts
Posted April 12, 2017 - 04:25 PM
Unfortunately, this is one of the manuals that isn't in the manuals section here.  Some awesome person needs to scan and upload one.  The brake/clutch doesn't work right now, but that's third on the list after this and fixing the steering.
#5 boyscout862 OFFLINE
  • 13,692 Thanks
  • 9,475 posts
Posted April 12, 2017 - 04:28 PM
Fixing the brake will probably be required to adjust the pedal. Good Luck, Rick
#6 chieffan ONLINE
  • 11,775 Thanks
  • 7,282 posts
Posted April 12, 2017 - 05:28 PM
I bet if you work on the clutch/brake pedal and get it right it will help the neutral positioning a lot also.
#7 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted April 12, 2017 - 05:36 PM
For your sake and sanity, I'll bet the 16H manual is real close!
  • boyscout862 and propane1 have said thanks
#8 Mustard Tiger ONLINE
Mustard Tiger
  • 157 Thanks
  • 166 posts
Posted April 12, 2017 - 06:14 PM
The ford yt16h?
  • propane1 said thank you
#9 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted April 13, 2017 - 05:18 AM
The ford yt16h?
Yes. I'm hoping so, anyway.
Went to NH and looked this up. Only see one spring for neutral return, #53.
http://www.messicks.com/nh/52115
#10 Mustard Tiger ONLINE
Mustard Tiger
  • 157 Thanks
  • 166 posts
Posted May 03, 2017 - 02:42 PM
In case anyone else ends up coming across this in a google search some day, the lgt 12 and 17 service manual has the info needed.  It is just loosening and then sliding the plate in that second picture, no need to have brakes.
#11 KennyP OFFLINE
  • 41,475 Thanks
  • 47,403 posts
Posted May 03, 2017 - 02:50 PM
That is good to know!
