Bending 1/2 inch thick flat bar
15 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,474 Thanks
  • 3,068 posts
Posted April 11, 2017 - 07:22 PM
I been think about a hitch for my wheelhorse I could buy one but what would be the fun in that. How do ya'll bend 1/2" thick flat stock ?
#2 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted April 11, 2017 - 07:23 PM
hot fire!
  • boyscout862 and bbuckler have said thanks
#3 olcowhand ONLINE
  • 41,194 Thanks
  • 31,429 posts
Posted April 11, 2017 - 07:25 PM
Yep, use a "blue wrench"!
#4 BigFlash OFFLINE
BigFlash
  • 244 Thanks
  • 132 posts
Posted April 11, 2017 - 07:27 PM
cut half way through it, bend it, fill in with weld and grind
  • boyscout862, Sawdust and bbuckler have said thanks
#5 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted April 11, 2017 - 07:32 PM
Take it to a buddy who has a press brake.
#6 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Big a** press, thats how my dad does it
#7 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted April 11, 2017 - 07:38 PM
   figure out what you need and take it to the locale welding shop, they will hook you up.
        Pete
#8 Sawdust ONLINE
Sawdust
  • 5,668 Thanks
  • 3,377 posts
Posted April 11, 2017 - 07:51 PM
Like Bigflash mentioned. I cutaway a v shape in the bend area with a right angle grinder leaving only enough to act like a hinge. Take a little more than a miter cut would take or it will cause the hinge area to break while bending...I know this for a fact. Then use your new welder to fill in.
  • boyscout862, HANKG and bbuckler have said thanks
#9 glgrumpy OFFLINE
  • 8,612 Thanks
  • 7,920 posts
Posted April 11, 2017 - 08:49 PM
Good vise and torch!  One thing I was told, was to heat the "Inside" of the bend to make it move easier. Never made sense to me, I always use outside, or both. Long enough heat on and it all gets red and bends like putty! Biggest issue is getting it bent straight and right angles. A drawing on a board or somewhere to hold it up to is good idea.
#10 JBRamsey OFFLINE
JBRamsey
  • 1,462 Thanks
  • 836 posts
Posted April 11, 2017 - 10:41 PM
I cut halfway through with a cutoff wheel. No need to make a vee and no need to fire up the torch. It will vee when you bend it to shape. It should be obvious, but you cut on the outside of the bend. Weld it back and dress it down as nice as you want it to be. I've never had problems with one breaking while bending. If you want to get fancy make a jig from scrap plywood and lumber to hold it in place when you weld it.
#11 Sawdust ONLINE
Sawdust
  • 5,668 Thanks
  • 3,377 posts
Posted April 11, 2017 - 10:50 PM
To each his own
  • MH81 and boyscout862 have said thanks
#12 secondtry OFFLINE
secondtry
  • 1,902 Thanks
  • 1,387 posts
Posted April 11, 2017 - 11:05 PM
I have witnessed the bending of a 3/4 X 4 flat bar using a chainsaw a tree stump and a pickup truck. A slot was cut in the stump to accommodate the flat bar. 6" of the flat bar was inserted in the slot, the pickup was driven into the bar sticking up from the stump. primitive but it worked Trying to decide how to bend a piece of 1/2 flat bar without knowing the width and having no idea what tools and equipment are available is a fools mission. I have bent a lot of steel with a big hammer. Don
#13 KennyP ONLINE
  • 38,391 Thanks
  • 45,938 posts
Posted April 12, 2017 - 04:45 AM
What type of hitch are you talking, trailer or a sleeve hitch? The WH I have here has a sleeve hitch and I wouldn't attempt one of those with out a torch, too many bends too close together.
I usually use heat and my 20 Ton press for bending metal when it will fit in there.
  • boyscout862 and Sawdust have said thanks
#14 chieffan OFFLINE
  • 10,164 Thanks
  • 6,642 posts
Posted April 12, 2017 - 07:09 AM
If you don't the right equipment to do the job don't try it. Draw out the bends you want on a piece of cardboard and take it to a shop with a big (200 ton) press.  They can do it right and a lot faster.
Edited by chieffan, April 12, 2017 - 07:09 AM.
#15 MolonLabe OFFLINE
MolonLabe
    Rust Wrangler
  • 551 Thanks
  • 320 posts
Posted April 12, 2017 - 08:28 AM
Are you designing something to work with the standard Wheel Horse "slot hitch"?
1/2X2" bar stock would be a tough cookie to bend. I tend to agree with the cut and weld option.
