S19 hydraulics
16 replies to this topic
#1 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 11, 2017 - 11:02 AM
Just purchased our 1st Speedex yesterday. Not sure how to check fluid for lift, It operates ok but will not stay in up position. Could be the valve. Any help will be appreciated. Thanks in advance!!
#2 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted April 11, 2017 - 11:30 AM
Hydraulic lift on S19?  I didn't think there were hydraulics on anything but the number series.  I wonder if you have an add-on.  PICTURES PLEASE!
In any case, if it raises but drops right back down it sounds like a valve.
  • boyscout862, rebel and 637Yeoman have said thanks
#3 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 11, 2017 - 11:56 AM
I'm not very good on getting pics from phone to laptop! Shoot me a number and can text them to you if you like! Thanks .. Gary
#4 glgrumpy OFFLINE
  • 8,809 Thanks
  • 8,014 posts
Posted April 11, 2017 - 04:04 PM
Yeah, wanna see too! Hydraulics?
#5 speedbird OFFLINE
speedbird
  • 295 Thanks
  • 149 posts
Posted April 11, 2017 - 08:39 PM
I think the 1631 and 1632 were the first to come from the factory with hydraulics.Of course I could be  wrong. It has happened before.
#6 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted April 12, 2017 - 06:22 AM
Here are the pictures rebel sent me:
  • rebel said thank you
#7 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 12, 2017 - 07:26 AM
Any thoughts??? If this was an add-on, someone did a lot of engineering. Open to suggestions, but we're gonna leave it as is. Maybe some one at Sugarcreek will know the tractor. Thanks Carl for putting pics up!!!
#8 MiCarl ONLINE
MiCarl
  • 2,206 Thanks
  • 1,122 posts
Posted April 12, 2017 - 07:51 AM
Hard to say but my thought is it's not factory.  The Speedex folks were known for making one offs though.  Since the Speedex factory was essentially a blacksmith shop any quality field modifications can look like original work.
One thing that would be a sure tell is if there is evidence of the manual lift lever being cut off.  It would have been welded onto that link that pivots around the left foot rest.  In the 3rd picture I posted I think I can see where it may have been cut off.
What I think I see in the pictures is an electric pump under the seat and a reservoir between the frame rails.  If that's a reservoir it'd normally have a drain plug on the bottom and a bung on top to fill and check the level.  It would also have a vent because the reservoir would have more oil with the cylinder collapsed than open.
I hope you make the Sugarcreek show.  I'd like to look it over.
Edited by MiCarl, April 12, 2017 - 07:58 AM.
#9 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 12, 2017 - 08:59 AM
We looked it over this a.m. and you are correct. The lift lever has been cut off!! Also, if my research is right, the S19 came with a Briggs. This one has the K181 with electric start. She came with turning plow, disc, mower deck, and back drag blade. Everything hooks up to rear lift easily !
#10 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted April 12, 2017 - 10:47 AM
I wouldn't have know if it was factory or not  but will say that it looks to be a very clean install ,, better then I could have done
#11 speedbird OFFLINE
speedbird
  • 295 Thanks
  • 149 posts
Posted April 12, 2017 - 03:04 PM
Speedex did us some Koler's usually in the S18 but with Speedex its possiable that is the original engine.Floyd.
#12 glgrumpy OFFLINE
  • 8,809 Thanks
  • 8,014 posts
Posted April 13, 2017 - 07:48 AM
How/where's pump?  It's Electric then, not off the engine at all?  Wouldn't think engine could keep the battery charged enough if used a lot? SO, you thinking like one of those all in one hydro units like for dumping trailers and snow-plows kind of unit?  Sure is jambed in there, hard to understand with just pictures for me at least.
#13 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 13, 2017 - 05:04 PM
The pump sits left to right just under front of seat and reservoir sit fore and aft in between frame rails.We're not touching anything until we take it to Sugarcreek next month. Hoping someone will recognize it and add some insight. The gent that owned it passed and his wife couldn't answer any questions. The pump runs off battery(actually looks like a big starter).
#14 glgrumpy OFFLINE
  • 8,809 Thanks
  • 8,014 posts
Posted April 13, 2017 - 07:51 PM
OK, so Sugar Creek is the big Speedex show???  Have a date and place for that?  Probly N-East and far away, just like the tractors, ha.  Have been there couple times for parts and Speedex tractors.  Takes all day for me to drive out and back.
#15 rebel OFFLINE
rebel
  • 1 Thanks
  • 10 posts
Posted April 14, 2017 - 06:07 AM
It's all vintage garden tractors. There are just a lot of Speedex around here. Sugar Creek, Ohio May 13, 2017. It will be just below the Dutch Valley Restaurant off St. Rt. 39.
