For Sale
1965 Sears Suburban 10x2 & 1966 Suburban 10
3 replies to this topic
#1 HulsPowered OFFLINE
HulsPowered
  • 25 Thanks
  • 22 posts
Posted April 06, 2017 - 07:42 AM
Starting with the '66 this tractor is complete, all good tires and the lights work. It runs and drives. No smoke. Has two issues, the ball joint on the steering sector is worn. It falls off sometimes. The throttle shaft area of the carb is worn so it revs high and won't idle. Nice machine with deck. $200
The "good" '65 tractor is totally complete, runs and drives. All good tires, no smoke, lights all work. The throttle cable needs hooked up at the lever. You can throw a battery in this tractor and go. Comes with a deck. $250
The other '65 this tractor is missing the belt gaurd. It does NOT run. Seems to be otherwise complete. Does turn over. Both front tires are shot, the left spindle thread needs chased so the wheel can be bolted on. Threads are only messed up at the very beginning. The flywheel pulley is no good. $125
Pick up in HOOPESTON IL
For more pictures 4257801493
  • hamman, Lmiller3358, Traill95 and 1 other said thanks
#2 heatseaker1 OFFLINE
heatseaker1
  • 27 Thanks
  • 36 posts
Posted April 08, 2017 - 05:47 PM
Thanks for the tractor, the boy will love it.
  • HulsPowered said thank you
#3 HulsPowered OFFLINE
HulsPowered
  • 25 Thanks
  • 22 posts
Posted April 10, 2017 - 12:01 PM
Middle tractor, the "good" 65 gone to a happy home.
66 and parts 65 still available
Edited by HulsPowered, April 11, 2017 - 12:16 PM.
#4 jpcubs OFFLINE
jpcubs
  • 6 Thanks
  • 24 posts
Posted April 27, 2017 - 06:44 PM
PM sent
