* * * * - 1 votes
Montgomery wards 3pt
6 replies to this topic
#1 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted April 04, 2017 - 01:20 PM
I found this Montgomery wards 3pt for a garden tractor like mine. Will it fit it? How rare are these and what do they run off, electric pto
  • hamman said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted April 04, 2017 - 04:53 PM
My wife's S-14H uses a long rod from the rock-shaft to the sleeve hitch. I am thinking that the same rod, or one somewhat like it goes from the rock-shaft to the 3 pt lift.
The hydraulic tractors with hydraulic lift would be so much easier.....Like our S-14H!
  • Montgomeryluv15 said thank you
#3 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted April 05, 2017 - 02:15 PM
So you think it will fit mine, has an Electric PTO that lifts the Mower deck
#4 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted April 05, 2017 - 06:23 PM
An electric PTO only makes the belts turn to make a mower or tiller work, not the hydraulic cylinder!
#5 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted April 06, 2017 - 03:15 PM
So thats a no?
#6 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted April 06, 2017 - 04:36 PM
I think you are misunderstanding what a PTO (Power Take Off) is......It is on the end of the engine crankshaft and turns a belt to run the mower. Some PTO's are turned on and off electrically with an electric coil like the air conditioner clutch on your automobile, and some are turned on and off by a manual lever.
The hydraulics' or manual lift of a garden tractor is what raises and lowers the mower or tiller, or dozer blade.
Now, you could have an electric actuator that raises and lowers the deck, but the actuator and PTO are completely different items and have completely different functions.
#7 Sprint 6 OFFLINE
Sprint 6
  • 256 Thanks
  • 311 posts
Posted April 10, 2017 - 05:47 PM
Looks like it might fit if yours is a model with mounts on the axle tubes.  Looks like to me that is where the lower arms mount.
