Steering gear sector
5 replies to this topic
#1 Tbevel OFFLINE
Tbevel
  • 6 posts
Posted June 11, 2011 - 05:19 PM
Getting ready to order a new gear sector for the Craftsman 19.5 Turbo Cool no. 917.259573. The teeth on the original are worn in the middle area allowing play in the steering and it appears to be made of Bakelite or some hard plastic. The replacement ones online look to be made of aluminum or cast. Am I right to think they are made of some type of metal and therefore might hold up better? thanks for any info.
#2 Tbevel OFFLINE
Tbevel
  • 6 posts
Posted June 15, 2011 - 07:05 PM
Ok I will answer my own question. After pulling the old one out I now realize it is metal also, so I need not worry that the new one is different.
#3 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted June 15, 2011 - 07:37 PM
Sorry nobody replied to your post. A lot of us use the what's new to check out new posts and sometimes they get buried pretty quick.
If the gear is cast it would definitely have that plastic look to from the grease coloring the metal over the years. Probably looks like the plastic type gears that are impregnated with lube to be self lubricating.
#4 NUTNDUN OFFLINE
  • 10,339 Thanks
Glad you did get it figured out and confirmed that it is the same gear. Also welcome to GTtalk.
  • Tbevel said thank you
#5 Tbevel OFFLINE
Tbevel
  • 6 posts
Posted June 26, 2011 - 09:53 PM
Thanks NUTNDUN for the info. I wish I could say that the tractor is back together but sometimes other people have plans for my every minute , sometimes for days and days and days,..... I sure hope none of you fellas have this problem!
#6 KennyP OFFLINE
  • 38,273 Thanks
  • 45,877 posts
Posted June 27, 2011 - 05:04 AM
That never happens around here.:bigrofl:
