GT 16 Engine Surge
47 replies to this topic
#31 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted March 27, 2017 - 08:55 AM
I just pull the intake side off, put my finger on to feel for vacuum. Low key method of educated guessing.
Thanks, Shorty.
With it being a hit or miss issue I'm not sure how to time it out.  I obviously can't run the engine with the fuel line off but I won't know if it's surging unless it is running...
I will try the gas cap vent, check the fuel lines and double check some more wiring and let you guys know what I find.
  • shorty said thank you
#32 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted March 27, 2017 - 06:45 PM
Hey guys, did some troubleshooting today and nothing I did fuel related helped. The only thing I could do to stop the surging was press the park/start switch.
I started it, put it in either forward or reverse just enough that it thought about moving and waited until it surged. When it started surging, I manually pressed the park/start button and it smoothes out. Release the button and it surged.
I know that isn't the proper fix, but I went ahead and jumped out the switch completely. I'll run it like this for a while and wait and see what comes of it.
#33 shorty ONLINE
shorty
  • 4,985 Thanks
  • 5,036 posts
Posted March 27, 2017 - 06:52 PM
Starting to sound like a wiring problem.
Could be up by the ignition.
Edited by shorty, March 27, 2017 - 06:55 PM.
#34 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted March 27, 2017 - 06:55 PM
I think it is wiring. Just not sure what exactly.
I also broke the hydraulic lever clean off the hydraulic valve. Snapped the end of the actuator off. Got any ideas how to fix that without buying a new directional control valve?
Not having a great day. Haha truck belt started squeaking, u-joint failed, lost all my transfee case fluid and then snapped the actuator on the tractor.
#35 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted March 27, 2017 - 06:56 PM
Ignition solenoid or the key switch ignition?
#36 shorty ONLINE
shorty
  • 4,985 Thanks
  • 5,036 posts
Posted March 28, 2017 - 05:01 AM
I was thinking the switch. I am finding it odd that closing that circuit eliminates the surge. I keep coming back to the thought that you are momentarily losing the ground with it open.
#37 tater195 OFFLINE
tater195
  • 2,032 Thanks
  • 1,349 posts
Posted March 28, 2017 - 07:44 AM
The inline spark test lights are handy for this. If you cant see it while test driving, an old school timing light works too.
#38 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted April 04, 2017 - 05:09 PM
Well guys, by jumping the switch I stopped the surge.
BUT...today I threw the mower deck on and now with the implement switch pulled to turn the deck on, it surges again. Back to chasing wires I go.
Edited by BoilerBrown, April 04, 2017 - 05:09 PM.
#39 shorty ONLINE
shorty
  • 4,985 Thanks
  • 5,036 posts
Posted April 06, 2017 - 06:39 PM
I think the that safety circuit from the park switch loops back through the pto switch. Then goes to the ignition and out to the solenoid.
#40 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted April 12, 2017 - 10:42 AM
Yes it does.
I jumped out the interlock module completely and have not had any issues yet.  I have mowed, pulled the roller, plowed the garden and ran the disc.  Zero issues as of yet.
#41 dodge trucker OFFLINE
dodge trucker
  • 2,135 Thanks
  • 2,852 posts
Posted April 12, 2017 - 12:23 PM
Did that make your hour meter crank away with no key IN/machine not running​? I tried to do the same with my gt19 and put many hours on the meter w/o the engine even running so I had to undo my 1st attempted work around. If push comes to shove I will rewire it from scratch using my 1972 new Holland as a template. I currently have a jumper and toggle temporarily between battery+ and the coil+. But haven't run the machine in a while because I have to pull the engine to put (another) starter on.
Edited by dodge trucker, April 12, 2017 - 12:24 PM.
#42 Billy M OFFLINE
Billy M
  • 620 Thanks
  • 534 posts
Posted April 12, 2017 - 01:13 PM
At least you have confirmed it's not mechanical or fuel related.  Now to fix those electrical gremlins!
Don't you love it when you get to "practice" pulling engines and replacing starters?!  :wallbanging:
#43 dodge trucker OFFLINE
dodge trucker
  • 2,135 Thanks
  • 2,852 posts
Posted April 12, 2017 - 05:44 PM
yeah. the original one had a sticky bendix, I had bought a pile of NOS, OEM Kohler stuff from a guy on CL that was ~50 miles away, guy was cool enough to ship it... lots of good stuff in that box. One thing that turns out isn't as good as I thought was a brand new starter for a KT/Magnum series engine. I had to take it apart as I remember and built 1 starter out of 2 (the original starter off this machine makes 3)  I had one sitting here that was shorter in length than the brand new one. I do not remember what I needed off of that extra short one. but the brand new one had a corner cracked off of one of the magnets fastened to the inside of teh starter case, but since I took the broken corner out and still had "most of" the magnet intact I thought it would be fine. but, no.
So now I gotta yank that starter and swap the end caps and bendix off of that one with the bad magnet and swap them to the original one, which worked but seemed a little "draggy".... hopefully raiding all the good parts from that new defective one, and swapping them to the original one, will net me 1 good starter. This will be the 3rd time pulling that engine to deal with starter issues.
#44 dodge trucker OFFLINE
dodge trucker
  • 2,135 Thanks
  • 2,852 posts
Posted April 12, 2017 - 05:46 PM
and THEN, I get to deal with the wiring headaches of the GT19....
When all is said and done, if I can only keep 1 tractor, I'm hoping it can be this one because it's the only tractor that I have ever had (of too many to remember) that actually has power steering.....
#45 BoilerBrown OFFLINE
BoilerBrown
  • 7 Thanks
  • 37 posts
Posted April 13, 2017 - 05:17 AM
My GT16 does not have an hour meter so I don't have the problem you have.
