FF20 engine question
3 replies to this topic
#1 Macgyver6 OFFLINE
Macgyver6
  • 67 Thanks
  • 17 posts
Posted March 26, 2017 - 09:18 AM
My B48G onan engine has an electric clutch on the crankshaft end so I can't tell what the diameter and length of the crank is. I have a spare P 220 engine from a Wheel Horse with an 1 1/8". Don't suppose I could be that lucky.
  • KennyP and chieffan have said thanks
#2 dropped82 OFFLINE
dropped82
    Nut Case
  • 2823 Thanks
  • 1940 posts
Posted March 26, 2017 - 09:19 AM
Yes it should be the same size and probably the most common. From my experience, John Deere ran a different size than the others. There's was 1 7/16". Most other Onans I've worked on or owned were 1 1/8"
Eric
Edited by dropped82, March 26, 2017 - 09:22 AM.
  • chieffan said thank you
#3 KennyP ONLINE
  • 52674 Thanks
  • 53138 posts
Posted March 26, 2017 - 09:25 AM
I can check my B48G. It does not have a PTO on it. Pretty sure it is the 1-7/16" crank. The other tractor I put a P220 in with no issue,but it had a clutch on it.
#4 KennyP ONLINE
  • 52674 Thanks
  • 53138 posts
Posted March 26, 2017 - 03:49 PM
My B48G has the 1-7/16" crank stub for the PTO.
