FF20 wheel question
6 replies to this topic
#1 Macgyver6 OFFLINE
Macgyver6
  • 52 Thanks
  • 12 posts
Posted March 25, 2017 - 09:31 PM
My tractor has a 6 bolt rear wheel. I was told they are filled probably calcium cloride. There's a very slow leak in one side. I'm going to take it down clean and replace the tube and reload with rv antifreeze. If I find a damaged wheel what will fit the tractor?
  • chieffan said thank you
#2 KennyP OFFLINE
  • 37,420 Thanks
  • 45,461 posts
Posted March 26, 2017 - 05:45 AM
#1, I would do some research on removing that calcium chloride. Nasty stuff.
#2, on the wheel repair (if needed), I had both back wheels on one of my FF's rusted through on the inside. I found a pair of donor 5 hole wheels and made a cut near center. Just welded those back on the FF wheel. They are doing fine. I'll see if I can find the thread.
Here it is.
  • TomLGT195 and chieffan have said thanks
#3 chieffan ONLINE
  • 9,558 Thanks
  • 6,404 posts
Posted March 26, 2017 - 07:59 AM
Take that wheel to an ag tire repair shop.  They are equipped to handle Calcium Chloride.  Use a vacuum pump to suck it out.  Like Kenny said, that is nasty stuff.
#4 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,545 Thanks
  • 961 posts
Posted March 26, 2017 - 08:28 AM
Ditto on the above, NOT worth the health risk ! If you get a measurement of your bolt hole centers, that would allow follow up to fitment , I'm going guess six bolt 12" GT wheels are the same (guessing)
I have several LF Bolens 6 bolt 12" rims if you have to go that route and they fit I can most likely help. (Shipping $ may suck)
  • rustyoldjunk and KennyP have said thanks
#5 KennyP OFFLINE
  • 37,420 Thanks
  • 45,461 posts
Posted March 26, 2017 - 08:36 AM
The bolt pattern is 6 on 6". Inside hole is right at 4-5/8". Might be able to get the offsets after a bit.
  • rustyoldjunk said thank you
#6 jimbobbillyray ONLINE
jimbobbillyray
  • 2,790 Thanks
  • 2,755 posts
Posted March 26, 2017 - 09:18 AM
there is a set of rear wheels for a ff for sale on Kansas City MO craigslist.  just do a search for sears FF.  John also ebays, he will ship
#7 Enginerod OFFLINE
Enginerod
  • 230 Thanks
  • 286 posts
Posted March 26, 2017 - 07:21 PM
I just measured my Massey Ferguson 1855 wheels today after reading this post, they are 6 lug 6" bolt pattern, the center hole measures 4 and 9/16" as close as I can get with the tape measure. Hope it helps.
