DIY Electric Garden Tractor Conversion
3 replies to this topic
#1 Little Eddie OFFLINE
Little Eddie
  • 50 Thanks
  • 16 posts
Posted March 24, 2017 - 05:03 PM
The perfect gift
Perfect gift for the handyman who has everything an ideal project,
       Make an electric garden tractor from your old gas tractor, and it could be charged by solar, zero pollution
Plans and instructions @ electrictractor.net
2hrs cutting approx 2 acres or 8-10 hrs pulling trailer on a charge
Converting to battery power is a great idea for a garden tractor I converted one 15yrs ago, I used the 3 separate motor design and it is still cutting grass on a daily basis, it is amazing how it never breaks down and needs almost no maintenance, I renew the batteries every 7 yrs I am just on my 3rd set now, my design will cut up to 2 acres on a 50cent charge there are no belts or pulleys and no oil on the entire tractor, it can pull a trailer for about 8hrs on a charge, because battery run time is the most important aspect of most conversions I paid particular attention to the most efficient design, I used 3 separate small motors one for the drive with electronic speed control and two smaller with a cutter blade mounted on the shaft of each cutter motor ,total amperage when cutting grass is approx 40amps, (2000watts) this design only uses the battery power req to do the job, very little wasted battery power, it uses magnetic breaking of both tractor and cutter blades and automatically applies parking brake when you stop or get off the seat, an amazing tractor.            electrictractor.net
         Video #5  Ploughing Snow
        Video #4 Ploughing Veggie Garden
 Video #3 The Little Electric Tractor That Can! cutting grass         Video#1 on youtube
         and https://youtu.be/9LWjfUjQ8a0
Edited by Little Eddie, May 01, 2017 - 10:53 AM.
  • DH1, sacsr, js5020 and 7 others have said thanks
#2 Little Eddie OFFLINE
Little Eddie
  • 50 Thanks
  • 16 posts
Posted May 06, 2017 - 07:38 AM
Here is a video on making an electric 3 point hitch for a garden tractor, the actuators can be sized to suite your application!
video #2  Making an electric 3 point hitch
  • DH1, Cvans, 637Yeoman and 4 others have said thanks
#3 John Arsenault OFFLINE
John Arsenault
  • 2,858 Thanks
  • 1,298 posts
Posted September 22, 2017 - 07:48 AM
Wow that is totally awesome. It takes a lot of thought to pull that off.
#4 lrhredjb OFFLINE
lrhredjb
  • 804 Thanks
  • 617 posts
Posted September 22, 2017 - 09:03 AM
That project seems like it would be a good use for an old treadmill motor. They are DC motors with controllers and about 1 hp if I remember.
Reply to this topic
