simplicity undermount grader blade - $195 (fredonia, WI)
2 replies to this topic
#1 Dan O OFFLINE
Dan O
  • 134 Thanks
  • 54 posts
Posted March 23, 2017 - 06:43 PM
Not mine. Not cheap, but not horrible either. Looks good, has a nice coat of paint.
For sale is a 42" undermount grader blade fits all large frame tractors $195
  • hamman, CRFarnsworth and 637Yeoman have said thanks
#2 Talntedmrgreen OFFLINE
  • 3,274 Thanks
  • 2,309 posts
Posted March 24, 2017 - 07:24 AM
Seems like a more than fair price for a refinished grader.  An average one would fetch $200 all day long.
This one, however, has an Allis/Homelite hitch.  The mounting points are a bit wider than a Simplicity grader, so someone wanting to use this on a Simplicity built tractor, would need to offset it on the mounting points.  For a ground engaging implement like a blade, that can be rough on the pins and mounting tabs.  The Homelite hitch is pretty rare...i've only see a few, ever.  Here are some closeups to show how the mounting points were widened to fit Allis and Allis-built Homelites:
  • hamman, sacsr, boyscout862 and 2 others have said thanks
#3 hamman OFFLINE
    Homelite Owner Extraordinaire
  • 6,480 Thanks
  • 2,874 posts
Posted March 24, 2017 - 08:22 AM
That is a nice blade. I still have to finish the one I've started for the T-16 H. I had to bend some steel like Josh showed to make the mounts work on the simplicity plow a frame I picked up. I have two extra snow blades and have cut one down to make the grader blade. I think it's a good price. wish it were closer and I could afford it. Thanks for sharing.        Roger
  • boyscout862 and Dan O have said thanks
