Gas tank sealer?
14 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,791 posts
Posted March 21, 2017 - 05:59 PM
What is the best way to seal a gas tank leak?? The blue line is the crack innthe tank.5f47959c91da6f8e6fde095cdb82ab23.jpg
Sent from my SM-S820L using Tapatalk
#2 poncho62 ONLINE
poncho62
  • 1,276 Thanks
  • 1,489 posts
Posted March 21, 2017 - 06:16 PM
That, I would solder it.........Clean it up real good, some flux and a big soldering iron, not a torch
  • backwoods, boyscout862, Bill 76 and 2 others have said thanks
#3 Bolens 1000 ONLINE
  • 14,612 Thanks
  • 17,952 posts
Posted March 21, 2017 - 06:25 PM
Red kote tank liner
Quality stuff
  • backwoods and boyscout862 have said thanks
#4 MiCarl ONLINE
MiCarl
  • 1,746 Thanks
  • 932 posts
Posted March 21, 2017 - 06:35 PM
Normally I like an epoxy sealer (which Red Kote is).  I wonder though if you don't have a structural problem there.
It looks like the flange is bolted or riveted to the tank and sealed with solder.  If the attachment is loose epoxy might eventually crack too, although I'd expect it to last longer than the solder.
#5 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,791 posts
Posted March 21, 2017 - 06:58 PM
It was resting on a piece of steel that should have had rubber between that an the tank. In this pic the brace on the bottom of the picture is right were it was sitting. So it caused some major vibration while running an caused the damage to the tank.
  • boyscout862 and 637Yeoman have said thanks
#6 Cvans OFFLINE
  • 6,008 Thanks
  • 5,870 posts
Posted March 21, 2017 - 07:43 PM
Yep solder would be my answer.
  • backwoods and MolonLabe have said thanks
#7 DZG ONLINE
DZG
  • 547 Thanks
  • 471 posts
Posted March 21, 2017 - 08:18 PM
Ive always had good luck with seal all, fuel leaks, radiators, its never failed me
  • Alc, backwoods, boyscout862 and 2 others have said thanks
#8 Kster526 ONLINE
Kster526
  • 732 Thanks
  • 477 posts
Posted March 21, 2017 - 08:26 PM
Solder then sealer on the inside. You've got it out that wAy your sure the
Crack is sealed on both sides of the tank
#9 EricFromPa OFFLINE
EricFromPa
  • 3,224 Thanks
  • 2,908 posts
Solder it then use red kote sealer.
If you just Epoxy it or JB weld it will leak as soon as gas finds a way under the epoxy. It might take a while but it always does.
  • Bolens 1000, backwoods and boyscout862 have said thanks
#10 adamjd200 OFFLINE
adamjd200
  • 1,928 Thanks
  • 2,076 posts
Posted March 21, 2017 - 09:29 PM
Red kote tank liner
Quality stuff
I use this stuff as well.
#11 Tecumseh power OFFLINE
Tecumseh power
  • 1,453 Thanks
  • 1,103 posts
Posted March 21, 2017 - 10:21 PM
Mig it
#12 adamjd200 OFFLINE
adamjd200
  • 1,928 Thanks
  • 2,076 posts
Posted March 21, 2017 - 10:55 PM
Mig it
That is fairly risky, heard too many bad stories about welding gas tanks.
#13 Kster526 ONLINE
Kster526
  • 732 Thanks
  • 477 posts
Posted March 22, 2017 - 06:10 AM
Agreed plus you'll have some distortion of the tank if you do it to quick. I've seen braising done also but feel that always ends up leaking again.
#14 backwoods OFFLINE
backwoods
  • 2,574 Thanks
  • 2,791 posts
Posted March 22, 2017 - 11:02 AM
I think I'm going to clean it up an reflow so of the solder then apply a few this coats of jb weld an also add a rubber cushion between the tank an cross member.
  • Cvans and adamjd200 have said thanks
#15 adamjd200 OFFLINE
adamjd200
  • 1,928 Thanks
  • 2,076 posts
Posted March 22, 2017 - 12:53 PM
I would still put red kote or something in the tank.
