John Deere gators
28 replies to this topic
#16 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted March 23, 2017 - 09:55 PM
I see I forgot to post the vid of the gator with the dead cylinder.
https://www.youtube....h?v=LYtgj3QVz-A
#17 Cvans OFFLINE
  • 5,025 Thanks
  • 5,360 posts
Posted March 23, 2017 - 11:51 PM
No oil pressure?
  • Cjet69 said thank you
#18 toppop52 ONLINE
toppop52
  • 4,059 Thanks
  • 3,850 posts
Posted March 24, 2017 - 09:35 AM
The cylinder works with choke on it, sounds like it's not getting fuel without choke.
#19 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted March 24, 2017 - 12:35 PM
No oil pressure?
That's what I'm thinking. Just have to pull that one down and take a look. Now to see if I can figure out the cyl. not firing in the other one.
That what has me stumped since both cylinders share the carb and manifold. Like Cvans said might be a problem with the runner on that cylinder. I may try the carb from the other gator and see if that helps.
#20 toppop52 ONLINE
toppop52
  • 4,059 Thanks
  • 3,850 posts
Posted March 24, 2017 - 04:09 PM
I don't know what engine, carb or intake you have, on my older 26 h.p. B&S, there is a two barrel carb and separate intake runners.
Edited by toppop52, March 24, 2017 - 04:10 PM.
#21 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted March 24, 2017 - 05:02 PM
Kawasaki FD620D water cooled. Basically the same engine that is in the JD 425, 445. I'll get a pic so you can see what it looks like.
#22 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted March 24, 2017 - 07:54 PM
Checked for leaks and found nothing. Decided to pull the carb and run through the sonic cleaner. Wasn't expecting anything to change, but fired it up and I have both cylinders firing.  :dancingbanana:  Why didn't I try that first.  :wallbanging:   On the upside the engine got a pretty thorough check up so I feel good about that. Now on to swapping the steering and tires and then maybe a test drive.
  • Alc and Cvans have said thanks
#23 Cvans OFFLINE
  • 5,025 Thanks
  • 5,360 posts
Posted March 24, 2017 - 08:30 PM
Congratulations!  :thumbs:
#24 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted March 24, 2017 - 08:36 PM
 Whats the saying? Even a blind squirrel finds a nut now and then. :smilewink:
Thanks for the input. I need all of the adult supervision I can get.
Edited by Cjet69, March 24, 2017 - 08:37 PM.
#25 toppop52 ONLINE
toppop52
  • 4,059 Thanks
  • 3,850 posts
Posted Yesterday, 08:52 AM
I pretty much knew it had to be fuel, you'd verified everything else. Glad you got it going. BTW, I have Kaw 20 h.p. liquid cooled in my 3208 Cub Cadet, I was going to look at it today.
#26 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted Yesterday, 12:52 PM
Thanks for the input. You were right, it was just to lean to run both cyl.  It just wasn't making sense to me that only the one side would fire when they share the carb and manifold.
  • toppop52 said thank you
#27 toppop52 ONLINE
toppop52
  • 4,059 Thanks
  • 3,850 posts
Posted Yesterday, 04:21 PM
There seems to always be a dominant cylinder, not sure why sometimes.
#28 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted Yesterday, 11:21 PM
Took the gator for a test drive this evening after swapping tires and steering from the other machine. So far it seems pretty good. I did notice that the drive belt pulley's don't completely stop and I get a little grinding when putting it in gear. Is there an adjustment for that?
#29 Cjet69 ONLINE
Cjet69
  • 332 Thanks
  • 203 posts
Posted Yesterday, 11:32 PM
Next up will be transferring the Linear actuator lift, hitch, headlights, and the best of the plastic body panels.
