john deere 240 Value?
3 replies to this topic
#1 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 20, 2017 - 11:24 AM
Hi everyone.
   I have this coming in on trade for work. Not running, engine turns over, has spark, but fuel supply issue. Client put a new carb for $240 on it, now it doesn't run. What is it worth? It did run and drive prior to him installing a new carb, but ran poor, so he bought the carb for it.
I'd love to sell it as a whole and move on, but may part it out too.
#2 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted March 20, 2017 - 12:41 PM
Check that fuel is getting to the carb. Probably crap in the tank or the fuel pump. Go over the whole thing. Sell it for $600 to $800. Good Luck, Rick
  • propane1 said thank you
#3 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,336 posts
Posted March 20, 2017 - 12:44 PM
Checked carb, fuel gets to carb, but that's it. I spray start spray in air filter, I get nothing. Valves were adjusted too, new spark plug and has spark.
#4 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted March 20, 2017 - 04:50 PM
Go to the troubleshooting guide in the engine manual. If a little raw gas in the carb won't get it to pop, then you have a timing or compression problem. Don't use starting fluid on small engines, it is too dangerous. Good Luck, Rick
Edited by boyscout862, March 20, 2017 - 04:51 PM.
