* * * * * 1 votes
Bolens 1886 Custom Wheel Project- Completed!
35 replies to this topic
#1 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted March 19, 2017 - 11:22 PM
Disclaimer: This project is not for everyone, and I want that to be clear. It is something most will not understand or find logic in, but that's OK. The good news, for you anyway, is that this project is designed to be a "reversible bolt-on endeavor" meaning the original parts (a wheel set in this case) will be retained and can be swapped back on at anytime like nothing ever happened.
Now that due-diligence is out of the way we can get into some details ....otherwise if this quite understandably isn't your cup of tea, you know where to find the back arrow. :)
___________________________________________
Briefing:
If you by chance saw my teaser a few weeks back, you'll remember that I had been working on a custom wheel project and was nearing completion. Here's the link: http://gardentractor...er/#entry749120
Mounting:
This project wouldn't have been possible without Lenny, the owner of Motorsport Tech, who I have build all my wheel adapters & spacers for my projects. The adapters are made in the USA, have a lifetime warranty, anodized, are hub centric with no cost spared in quality. These things aren't cheap.
The rears:
The rear wheels are where it gets fun and all the magic happens. While I've had a lot of spacers made in the past, I've never actually gone from one bolt pattern to another so I got to learn about a new type of adapter. In this case where going to call them spacer-adapters.
The spacer-adapters themselves are 2-piece- (apparently a design created by them as Lenny explained) because we're going from one bolt pattern to another- 6 lug to 8 lug so it would be impossible to have a one-piece design in order to access the lug nuts on the hub side- (it makes more sense if you see this in person).
(The slight discoloring you see is simply some smeared anti-seize)
I love this shot! :)
The way it works is you bolt one half to the hub the wheel hub, and then the second half of the adapter slides on via two dowel pins and then is bolted on via 8 included allen bolts. The total thickness of the rear spacer-adapters are 1.5" and are the thinnest possible Lenny could make them in this configuration. I could've purchased these same rims in a 6-lug design but they still would not have been the 6x6 lug pattern and rather 6 5.5" lug pattern requiring the same type of spacer-adapter. I chose the 8-lug pattern for extra uniqueness and also to coincide for fun with one of my other hobbies, diesel trucks.
The Fronts:
The fronts are pretty simple as the new rims share the same lug pattern and size as the originals. They however have less backspacing than the factory rims so due the bigger tires, they needed to be spaced out more to prevent rubbing. The front spacers are 3".
Impressions:
It certainly has different vibe to it for sure. The 29's which are closer to 30" than 29" are a big jump up from the 26s's that measured closer to 24.5" that were on before; they really filled up the large gap between the fender and tires. So far it seems to work fine and still be as functional for what I use it for which was the goal despite it being a little wider which has its advantages & disadvantages. I had the front spacers made to a spec to not allow rubbing on the front and little things like that I think made the difference in order for it to work. Will I keep this setup forever? Who knows, I might even switch it up something different in the future. At least there is the original wheel set to go back to that can be bolted back up easily.
Stock Dimensions: (The dimensions were taken from the top of the hood in the front, below tail light in the rear and the outside wheel widths. This doesn't really matter though as it's the actual differences which do for a simple comparison sake here.)
Front Height: 41"
Rear Height: 22.6"
Front width: 43"
Rear: 46"
Current Dimensions:
Front Height: 42.5" (1.5" increase)
Rear height: 26.25" (3.65" increase)
Front Width: 47" (4" increase)
Rear Width: 49.5" (3.25" increase)
What is it like to drive?
Well, to be honest, not really much different. If I were blindfolded and asked which wheel setup it had, it wouldn't be as apparent as you might think. The thing I notice most is that it's a little speedier. In comparison before, it felt like it was always in "granny gear" while now it feels like it's in 1st. Basically it takes less pedal travel to go faster is the best way I'd describe it. The difference is subtle but I'd say you have to be a little more mindful with your foot when maneuvering around tight areas because less pedal travel does more work so to speak. You would assume the steering wheel would be night and day heavier with the spacers and bigger font tires, right, but it is not much different.
I guess the other thing I'd add is that it has a firmer ride. The 26" Tru Powers on it before were 4" ply and had a lot more give to them; in fact it was basically like riding on big cushy marshmallows as they were always squished down and would even develop flat spots after a while if you let the tractor sit for a while. The 29's are firmer and a lot more stout in that regard. I could see this potentially being a detriment, but time will only tell. The good news is that there is even more weight in the back (the rears took 20 gallons each of RimGuard compared to the 11 gallons in the 26s and should equal out to about what they did with the weights too given the significant increase in fluid) and the Tru Powers themselves are a soft compound. The tractor seems to have quite a bit less rolling resistance because of it. The parking brake has to be used more. You could not push the tractor in neutral simply because it was like pushing with flat tires in the rear; now you can. Just observations that you can take as you please.
Alright, enough about wheel spacers, let's back this little beast out of the trailer and have a photoshoot!
Edited by Austen, March 20, 2017 - 12:31 AM.
  • jhn9840, Gtractor, Alc and 23 others have said thanks
#2 Mark 149 J. OFFLINE
Mark 149 J.
    Mark J.
  • 4164 Thanks
  • 2180 posts
Posted March 20, 2017 - 12:06 AM
I think she looks good in her new shoes!
Those wheel adaptors look top notch and the rims give your tractor a very unique look!
Are the rims powder coated?
It looks like it sits higher then it did before.  Could you put a before and after picture to see the difference.
  • Austen and stiemmy have said thanks
#3 Clevis OFFLINE
Clevis
  • 754 Thanks
  • 305 posts
Posted March 20, 2017 - 12:37 AM
#4 Austen OFFLINE
Austen
  • 3722 Thanks
  • 1470 posts
Posted March 20, 2017 - 01:02 AM
Thanks, yes, I had them powder coated.
It does sit a little taller and wider than before. Here's the before and after specs:
Stock Dimensions:
Front Height: 41"
Rear Height: 22.6"
Front width: 43"
Rear: 46"
Current Dimensions:
Comparison shots:
  • Alc, wvbuzzmaster, blackjackjakexxix and 6 others have said thanks
#5 fonz3482 OFFLINE
fonz3482
  • 1913 Thanks
  • 890 posts
Posted March 20, 2017 - 02:20 AM
Man what a difference!! To be honest the tractor looks great either way! The 1886 with its classic Bolens styling has always been a favorite of mine and yours is a top notch machine! The new spacer adapters you had made up are very nicely made!! With the bigger tires on the tractor it looks awesome, But it does make the loader and Gannon look small! LOL! One thing I will tell you from experience, When I went from stock tires on my 1050 to larger atv tires that filled the wheel well up I had to really think about what I was doing while operating the tractor. What I mean by that is I was accustomed to grabbing the fender lip on either side of the tractor and leaning to see better, or when jumping off the tractor. Well I did that a few times and learned my lesson real quick when my fingers got pinched between the aggressive tires and the fender. I'm not sure if you do the same, but those bigger tires sure fill the wheel wells and it looks like its a possibility, so I just thought I'd throw that out there for safety purposes!
  • Alc, blackjackjakexxix, KennyP and 5 others have said thanks
#6 KennyP ONLINE
  • 53210 Thanks
  • 53322 posts
Posted March 20, 2017 - 05:16 AM
Looks good! And I like the fact it can be put back with no issues!
  • WrenchinOnIt, Austen, stiemmy and 1 other said thanks
#7 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 19122 Thanks
  • 11904 posts
Posted March 20, 2017 - 06:31 AM
Have you noticed picking up more women than before?
  • Austen, bprzyw, stiemmy and 1 other said thanks
#8 Jazz OFFLINE
Jazz
  • 2756 Thanks
  • 1585 posts
Posted March 20, 2017 - 06:39 AM
Looks balanced to me. I like the new boots.
Edited by Jazz, March 20, 2017 - 06:39 AM.
#9 Kster526 ONLINE
Kster526
  • 2907 Thanks
  • 1248 posts
Posted March 20, 2017 - 06:42 AM
Excellent, job well done . I am so jealous.
I have a picture in my head of doing something like that on one of my RF JD 110's and you have given me so many more ideas.thank you .
The pics of it are great in front of the building.
#10 HANKG OFFLINE
HANKG
  • 6962 Thanks
  • 3671 posts
Posted March 20, 2017 - 07:06 AM
Austen, that is a fine looking machine the wheels and tires look great very nice upgrade. I have seen products from Bora they make excellent machined parts.
#11 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted March 20, 2017 - 07:36 AM
Nice pics but I was wishing I would see a pic of the underside also.
#12 Traill95 ONLINE
Traill95
    Traill95
  • 2051 Thanks
  • 1082 posts
Posted March 20, 2017 - 08:10 AM
:thumbs:  :thumbs: :thumbs:
#13 tiretrx OFFLINE
tiretrx
  • 2308 Thanks
  • 1238 posts
Posted March 20, 2017 - 08:50 AM
Sharp as a razor, Austin. Nicely done, sir!
#14 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 8082 Thanks
  • 4782 posts
Posted March 20, 2017 - 08:57 AM
Very nice! It will be hard to get that dirty!
#15 ericjr16 OFFLINE
ericjr16
  • 1114 Thanks
  • 594 posts
Posted March 20, 2017 - 09:39 AM
Very nice Austen!! Tractor porn!
  • Austen, stiemmy, Jazz and 2 others have said thanks
