* * * * * 3 votes
Hulk II (1988 Craftsman II) 917.255919 Summer Refresh.
268 replies to this topic
#226 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted July 30, 2017 - 05:30 PM
Been running in and out of the heat today sanding, cleaning, and painting parts. If anyone is sitting on a 44" (106022X) deck belt cover I am very interested! Most of the big parts are painted (first coat) I'll flip them over after supper and do the other side. Still need to clean up the plastic parts, then move on to the main deck. Pretty good day over all here.
  • KennyP and UncleWillie have said thanks
#227 Whizdbiz2 OFFLINE
Whizdbiz2
  • 8 Thanks
  • 14 posts
Posted August 01, 2017 - 11:59 AM
Looks like JD Green to me!
  • larrybl said thank you
#228 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 01, 2017 - 03:04 PM
Slightly darker than JD Green, but lighter than the Forest Green I would have preferred. Made some magnet badges, and his tattoo.
#229 Whizdbiz2 OFFLINE
Whizdbiz2
  • 8 Thanks
  • 14 posts
Posted August 02, 2017 - 06:56 AM
I've used my mower jack all of about 2 times in five years. Never seems to be right for the job needing done. Great job on the restore!
#230 UncleWillie OFFLINE
  • 15,547 Thanks
  • 8,714 posts
Posted August 02, 2017 - 07:06 PM
Nice
#231 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 03, 2017 - 08:16 PM
Looks like the deck needs more TLC than I remembered. After a good cleaning I discovered some issues. Not sure I have enough JB for what I need to do to the deck carcass, but the JB should work well. The previous painting has held back further rust for the most part, but I need to address this now. Divots the size of moon craters, Some small rust through on the rear, and rust blisters. Good news these are mainly on the back and under the cover area. Started chipping the blisters off and wire brushing the back area. The only way to eat an elephant is one bite at a time. Good news is the blades are still like new. Mandrills spin fine, but I am thinking on new ones and using these on the third deck I got from Brandon. Lots of detailed sanding ahead.
Edit: PC locked up and I had to re boot to add the rest of the pictures.
Edited by larrybl, August 03, 2017 - 08:26 PM.
  • jhn9840 and KennyP have said thanks
#232 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 03, 2017 - 09:17 PM
It's going to be a learning curve, Art, and patience curve JB-ing the deck. Started on the worst rust through area. This will need to dry, then sand and a second coat, and sanded again. I'll need to do this on several areas.
#233 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 04, 2017 - 07:35 PM
I think this is going to work, but will take time. I let the first coat cure 24 hours, then this evening I sanded it down till I saw metal, then wiped it down and applied a second coat, It smoothed out well! This was the worst area with the rust through holes. 1/4 - 1/2 tube of JB on this. Rest is just filling divots and sand smooth.
#234 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 05, 2017 - 08:42 PM
OMG! Just got back on-line. Had to re-format the puter, Install Win-7 and all the updates including Service pack-1. Still installing all the accessories (My printer requires XP drivers). Any how, I am back. The JB experiment is still going well. I picked up three more packs, so far I have used 2-1/2 on the worst area. I am picking a small area to work on each time. You have to use a welders hammer to remove the rust bubbles as the wire brush or sander won't. Then wire brush the area good. Then sand with 80 grit. Wipe the area down good then apply JB using a rubber body filler tool and get as smooth as possible. Let dry 24 hours and sand with 220 Grit. Apply JB again (sometimes using a finger) to spread smooth. 24 more hours and sand with 340 with the mouse sander and hand sand. Move on to the next area and repeat, (touch up previous area as needed when JB is mixed). Some areas take three applications to get smooth. Still need FireFox to paste text here.
#235 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 06, 2017 - 06:37 PM
Stuck with Fire Fox for now. With the Computer issues, I was able to get most of the deck divots filled in. Still needs some sanding and a couple more JB touch-ups, but should look good when the paint is on. I also ordered new mandrills so this will be the "Show" deck. I'll work on the "mowing" deck I got from Brandon later.
Edited by KennyP, August 07, 2017 - 05:04 AM.
Add Pic to post
#236 UncleWillie OFFLINE
  • 15,547 Thanks
  • 8,714 posts
Posted August 06, 2017 - 07:15 PM
I use Chrome. I liked FireFox, but on my turd slow internet it would not work right.
  • larrybl and KennyP have said thanks
#237 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 07, 2017 - 09:31 PM
The JB experiment is still on going. Small sections are done during week day evenings. Once I get the divots filled I'll take this outside for a fine sanding all over, and apply s couple more touch-ups. So far it is looking way better than when I started. I am on my 4th pack of JB right now, and that should do it. The time consuming  part is waiting on the JB to dry for sanding.
#238 Alc OFFLINE
  • 6,751 Thanks
  • 7,399 posts
Posted August 08, 2017 - 05:28 AM
Larry for the amount of resto's you do would buying a can of All-Metal be more cost effective then JB Weld ?  ( Sorry I can't paste a link )
#239 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,858 Thanks
  • 4,350 posts
Posted August 08, 2017 - 11:30 AM
The JB allows for mixing and applying small quantities at a time. So far around $15.00 of JB has been used. I spend more on mouse sand paper.
#240 bbuckler ONLINE
bbuckler
  • 3,330 Thanks
  • 2,989 posts
Posted August 08, 2017 - 03:33 PM
Think JB would work on my broken dash on the 16/6 ?
