* * * * * 3 votes
Hulk II (1988 Craftsman II) 917.255919 Summer Refresh.
268 replies to this topic
#166 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 01, 2017 - 04:17 PM
Waldo has to be the White thing in the center of the first pic.
  • larrybl said thank you
#167 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 01, 2017 - 04:36 PM
Good try, That white thing is a tank at SpaceX
Edited by larrybl, July 01, 2017 - 04:38 PM.
#168 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 01, 2017 - 04:37 PM
Good try,
Heck, you hid him!
#169 UncleWillie OFFLINE
  • 16,257 Thanks
  • 8,975 posts
Posted July 01, 2017 - 06:14 PM
Text of Copy and paste
Busy day, see if you can find Waldo, I got going at 7:00am and weed wacked the fence line and around the buildings, then used the push mower to go along the fence and under the trees and bushes. I was doing this in the picture my Wife took. A T-Storm came through and cooled it off for about 30 minuets. After the push mower I got RED out and rode the three + acres. Cleaned RED up, and after everything was put away it was 3:00pm.
On a side note, I got the mower jack out to clean under the deck. You can't lube the front end with the mower jack. I still had to use the floor jack. I think this was the third time I have used this jack, I think I'll sell it.
Still waiting on paint to dry.
  • jhn9840, larrybl and KennyP have said thanks
#170 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 01, 2017 - 06:22 PM
Wonder if it is my computer?
#171 UncleWillie OFFLINE
  • 16,257 Thanks
  • 8,975 posts
Posted July 01, 2017 - 06:25 PM
Have you tried turning it off and back on again???? :watch_over_fence:  :watch_over_fence:  :D
#172 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 01, 2017 - 06:49 PM
Changed over to Fire Fox, seems to work now. Must be an IE issue..... What a pain!
#173 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 01, 2017 - 09:44 PM
Slow night, watching NASCAR. got parts ready for cleaning tomorrow, but have some honey doo's to do. Tins are done.
#174 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 02, 2017 - 09:03 PM
Going together, Still waiting for paint to dry on some fasteners Most of the engine is done except the starter. I need to put the pool up this week as my Grandson will be staying for an extended visit.
#175 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 03, 2017 - 10:24 PM
Was moving right along tonight then realized before I put the tins on I need to install the starter. So I tore it down tonight\. I'll clean it up and paint it in the morning. Then the re-assembly can continue.
  • KennyP and UncleWillie have said thanks
#176 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 04, 2017 - 11:46 AM
Waiting on more paint to harden, and had to back track some. Can you spot the difference between these two pictures?
#177 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 04, 2017 - 02:59 PM
Plate under the throttle linkage!
#178 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 04, 2017 - 03:04 PM
Hint.
  • bprzyw said thank you
#179 KennyP OFFLINE
  • 40,949 Thanks
  • 47,132 posts
Posted July 04, 2017 - 03:11 PM
And you turned the intake around!
  • larrybl and bprzyw have said thanks
#180 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,470 Thanks
  • 4,584 posts
Posted July 04, 2017 - 03:28 PM
Yes, the intake can be installed backwards, and everything still lines up fine till you try and connect the throttle cable. The bolt on the manifold would have been on the wrong side. Glad I caught this when I did. Having a time putting the starter together now. The brush housing is attached to the stator and when I go to install the stator in the housing the magnets pull the stator and the brush housing comes off. Then I have to push the brushes back in with plastic clips to get it back on the stator. Twice now..... Third time I am trying a different method.
  • KennyP and bprzyw have said thanks
