* * * * * 3 votes
Hulk II (1988 Craftsman II) 917.255919 Summer Refresh.
268 replies to this topic
#151 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 23, 2017 - 09:40 PM
Doing some checking on the heads and cylinders tonight. I'll get the valve clearances in the morning.
  • UncleWillie and bprzyw have said thanks
#152 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 24, 2017 - 11:26 AM
Specifications for the 422400 SB attached.
Not sure if I want to replace the valves on this. I replaced them 7 years ago, and the specifications are real close. I measured with the springs installed and came up with,,,
Left Intake = 0.005 (Dead on)
Left Exhaust = 0.009 (Good)
Right Intake = 0.008 (0.002 off)
Right Exhaust = 0.011 (0.002 off)
Everything is clean, looks to have burned even on both sides, very little carbon (could because I mix STP and Stabil in the gas).
I am leaning towards a de-carbon and button it back up.
  • bprzyw said thank you
#153 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 24, 2017 - 11:13 PM
I'll leave it as it is, The spare engine sounds the same. Both bored to .002 over, new valves rings and pistons 7 years ago,
https://www.youtube....h?v=9hd2gnypDRc
  • KennyP and bprzyw have said thanks
#154 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 24, 2017 - 11:15 PM
Movie time tonight in the man cave. Gave me an opportunity to get some outside pictures.
  • Alc, KennyP and bprzyw have said thanks
#155 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 24, 2017 - 11:47 PM
Hulk II will be getting the same LED light upgrade.
https://www.youtube....eature=youtu.be
#156 UncleWillie OFFLINE
  • 16,260 Thanks
  • 8,975 posts
Posted June 25, 2017 - 11:38 AM
Doing a great job keep it up
  • larrybl and bprzyw have said thanks
#157 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 25, 2017 - 12:18 PM
Got some whip lash this morning, I moved all the tractors out for a shop sleep over and movie time last night. Went to move the tractors closer to the shop this morning incase of rain. I fired up Old Girl to move, put in 2nd HI and let the clutch out (I swear slowly). Well it grabbed and I pulled a wheelie, seat spring bottomed our (thank goodness for the hi back seat, and literally jumped off the pergola. Now I have a kink in the middle of my back.
#158 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 25, 2017 - 12:45 PM
Detailed the block with the wire dremel and have a second coat applied. still a chance of rain so I don't want to get too many parts that I would need to bring in. Waiting on paint to dry.
#159 UncleWillie OFFLINE
  • 16,260 Thanks
  • 8,975 posts
Posted June 25, 2017 - 03:38 PM
Old girl is ready to run.
#160 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 26, 2017 - 09:00 PM
On the Briggs Opposed there are two valve breathers. There is a "brown reed valve" that needs to move freely, and oil drain ports that need to be open. Inside is a nylon screen that needs to be intact. Installation requires three gaskets. This is my one thing to do each work evening. Next up is the stator coil.
#161 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 27, 2017 - 09:11 PM
Really thinking of changing jobs.
Small Engine Repair/Tractor Delivery Position
Pineco Tractor & Equipment - Waco, TX 76706
$30,000 - $50,000 a year
Any how, after a grueling day at work, I re-taped the shroud bolt holes. I had used self-tapers with the drill part cut off previously.
#162 UncleWillie OFFLINE
  • 16,260 Thanks
  • 8,975 posts
Posted June 27, 2017 - 10:20 PM
Getting there.
#163 KennyP OFFLINE
  • 40,961 Thanks
  • 47,139 posts
Posted June 28, 2017 - 06:33 AM
Looking good Larry!
#164 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted June 29, 2017 - 07:40 PM
Can't cut-n-paste to this site for some reason??? Ordered a seat, I'd paste the link if I could, Picked up some stuff at TSC.
#165 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,474 Thanks
  • 4,584 posts
Posted July 01, 2017 - 03:59 PM
See attached, I ain't typing it again.
