Will a 18 x 9.50x8 tube work in 20x10x8? was i lied to by Co op?
6 replies to this topic
#1 aftonarrow OFFLINE
aftonarrow
  • 1 Thanks
  • 8 posts
Posted March 19, 2017 - 09:16 AM
HI,went to my local co op to get a tube for a 20x10x8 rear mower tire.The kind gentleman behind the counter told me that a 18x9.50x8 tube will work.He said they used it for 20''s before.I don't see how this is going to work but will try if anyone has used one before.Seems to be it will be too tight for the tire and the tire will not be fully inflated and cause the mower to deck to be unlevel.
#2 chieffan ONLINE
  • 9,523 Thanks
  • 6,393 posts
Posted March 19, 2017 - 09:23 AM
Should work with no problem.  The tube will stretch that much.  Only 1/2 " in width and 1" each side for height.
  • boyscout862, old coot and propane1 have said thanks
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,100 Thanks
  • 4,879 posts
It'll be fine plus less of a chance getting a wrinkle in the tube.
  • olcowhand, Cvans, boyscout862 and 1 other said thanks
#4 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted March 19, 2017 - 09:25 AM
Yes that tube will work fine. It will inflate big enough to fill up the tire safely. The 8 measurement is the one you have to be concerned with which is the rim diameter. Hope this helps.
  • boyscout862 and old coot have said thanks
#5 olcowhand ONLINE
  • 40,323 Thanks
  • 31,162 posts
Posted March 19, 2017 - 12:01 PM
No problem there!
  • old coot said thank you
#6 toppop52 OFFLINE
toppop52
  • 5,009 Thanks
  • 4,626 posts
Posted March 19, 2017 - 01:35 PM
I've done it myself.
#7 old coot ONLINE
old coot
  • 108 Thanks
  • 82 posts
Posted March 23, 2017 - 05:10 AM
i worked in a tire shop when out of high school...that will work , no problem
