Terramite front bucket
7 replies to this topic
#1 mthome OFFLINE
mthome
  • 1 posts
Posted March 18, 2017 - 03:13 PM
My T5C front bucket has stopped working. No lift, no tilt.
Backhoe hydraulics work fine.
See no fluid leaks.
Has anyone else had a problem with front bucket?
#2 637Yeoman OFFLINE
637Yeoman
  • 1,690 Thanks
  • 1,362 posts
Posted March 18, 2017 - 04:43 PM
Sorry i cant help. but welcome to the forum. Im sure someone will be here to help you soon
#3 Mtypython OFFLINE
Mtypython
  • 374 Thanks
  • 352 posts
Posted March 18, 2017 - 05:40 PM
might be the control valve for the loader, at idle  engine rpm should drop when u try to use bucket, if it dont takeoff a line from valve body outlet to bucket or lift pistons and try control at idle just a tiny bit to see if any fluid is going to piston from valve, all i can think of
#4 boyscout862 OFFLINE
  • 13,689 Thanks
  • 9,474 posts
Posted March 18, 2017 - 06:49 PM
Welcome to GTT. It sounds like the valve set for the loader. Check our Manuals Section for the manual. Good Luck, Rick
#5 James Bosma ONLINE
James Bosma
  • 1,585 Thanks
  • 753 posts
Posted March 18, 2017 - 08:20 PM
Wonder if the valve body has a pressure relief valve, if so it could be stuck open
#6 chieffan OFFLINE
  • 11,767 Thanks
  • 7,278 posts
Posted March 19, 2017 - 07:46 AM
Could have blown the cylinder seals so everything goes by instead of pushing.
#7 KennyP ONLINE
  • 41,457 Thanks
  • 47,388 posts
Posted March 19, 2017 - 08:01 AM
That's where I would start. Loosen a line on one of the lift cylinders and see if fluid leaks out. Also, look at the lines to the bucket valves from the pump. There may be a valve there that has gotten turned off not allowing fluid to go to the valve.
#8 KennyP ONLINE
  • 41,457 Thanks
  • 47,388 posts
Posted March 19, 2017 - 08:07 AM
Also, which model is this? I googled for manuals and there are some here, might find one for your tractor.
  • 637Yeoman said thank you
