Snow plow questions
6 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 17, 2017 - 09:00 AM
Ok so the spring fell off the lock the other day while plowing I did get it back together but it looks like something is broke off it. An the other is what is this bracket supposed to do that I took off??409986d326939b55d8a60416d3502cc1.jpg
Sent from my SM-S820L using Tapatalk
#2 glgrumpy OFFLINE
  • 8,549 Thanks
  • 7,877 posts
Posted March 17, 2017 - 06:38 PM
This a Power King blade?  Looks like the spring just slips back into the lock tab there. Maybe a little more bend on it's end will keep in better?  Where was this other bracket?  In same area?  Not getting WHERE you took it off from.  Maybe just a lock tab for ??
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted March 17, 2017 - 08:46 PM
1.
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 17, 2017 - 08:54 PM
Sorry this is on a Gravely 48" plow
#5 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 17, 2017 - 08:55 PM
The l bracket was towards the forward /reverse lever on the trans but bolted to the blade
#6 case442 ONLINE
case442
  • 693 Thanks
  • 423 posts
Posted March 18, 2017 - 03:40 PM
thats the foot to keep the blade up so you can drive the tractor into the catches on the rear axle.
Mike
  • backwoods said thank you
#7 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 18, 2017 - 04:14 PM
Ok so when I get ready to remove the blade I'll reinstall it
