New project I picked up
19 replies to this topic
#1 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 16, 2017 - 05:46 PM
I think it is a 78. Serial # 917.253176. Is this a sububan?
  • Gtractor, hamman, KennyP and 5 others have said thanks
#2 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted March 16, 2017 - 06:36 PM
Are those atv wheels on the front ? What are your plans for it ?
  • wcl400 said thank you
#3 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 16, 2017 - 06:48 PM
Im not sure what the wheels are. I have the origanals too but will not hold are. I just plan to get it running and looking better. It came with a 46 inch blade I am hoping to modify for my FF-18. Just have fun and use it as a learning project.
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted March 16, 2017 - 07:30 PM
Yes that has the same frame as the suburbans. That should have the briggs twin. Good tractors i have the gt 18s i have 3 of them and love them. Yours is a 1978
#5 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted March 16, 2017 - 07:31 PM
Yours is the the first one i ever saw besides mine with the speed hitch plow mount
#6 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 16, 2017 - 07:50 PM
Unfortunitely one side is broken.
#7 secondtry OFFLINE
secondtry
  • 1,897 Thanks
  • 1,386 posts
Posted March 16, 2017 - 07:56 PM
   Should be an easy fix if you have some welding capability. To bad we are so far separated I could fix that for you.  Don
Edited by secondtry, March 16, 2017 - 08:00 PM.
  • Sawdust and wcl400 have said thanks
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted March 16, 2017 - 08:17 PM
I agree welding that bottom corner is an easy fix if you can weld or have a friend who can
#9 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 16, 2017 - 08:26 PM
I do not weld myself even though I want to learn, but I do know someone that has a small engine repar bussiness that may be able to help me. He does a lot of stuff.
#10 secondtry OFFLINE
secondtry
  • 1,897 Thanks
  • 1,386 posts
Posted March 16, 2017 - 08:57 PM
   There again to bad it's like a 500 mile round trip I could show you how and let you do it yourself. Don
#11 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 16, 2017 - 10:28 PM
Yea I wish we were closer!!
#12 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 17, 2017 - 06:46 AM
Yes it is a suburban. That should have the briggs twin. Good tractors i have the gt 18s i have 3 of them and love them. Yours is a 1978
x2, 1978 was the first year Sears used a Twin briggs in a suburban. I heard a lot didn't make it cause they had oiling issue if the oil level ran low, but then I see good running ones pop up here and there. Either way, Sears didn't make a ton of the 16 Hp that yr. Most suburbans had a single Tecumseh or twin Onan up to this point.
You have the typical broken upper nose cone, never seen the rubber hold down approach used on one to hold the hood on.
  • Alc and wcl400 have said thanks
#13 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 17, 2017 - 07:30 AM
Yes it has the Briggs & Stratton twin and the broken nose cone.l am going to find a way to modify the hood to fix that if anyone has a fix I hope they will let me know. The only issue with the motor is it needs a new coil. Pulling that of todat to get the part # Got the thing for almost nothing, so just having fun and learning more about the hobby. Everyone on here has been great.
#14 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted March 17, 2017 - 07:48 AM
I've seen tons of fixes for the nose, it depends on what you want it to look like and if you just want function over form or both. It's fiberglass so it can be built back up and finished off nice. I preferred to build a metal frame underneath then cover.
That nose has to be one of Sears/Ropers worst design flaws in the suburbans.
#15 wcl400 OFFLINE
wcl400
  • 29 Thanks
  • 48 posts
Posted March 17, 2017 - 09:05 AM
I think I will just fix it with fiberglass, but would like to see what you did.
