m/w gilson variable speed 16
10 replies to this topic
#1 Xrperry OFFLINE
Xrperry
  • 971 Thanks
  • 740 posts
Posted March 16, 2017 - 01:28 PM
i have a question. the old cast iron briggs 16 i have backfires when i shut it down. not a huge muffler splitting bang,just a pop. anyone know why its doing this?. the thing runs like a top, kinda irritating when it pops
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,454 Thanks
  • 1,104 posts
Posted March 16, 2017 - 01:42 PM
https://www.briggsan...-afterfire.html
  • gopher, boyscout862, TomLGT195 and 1 other said thanks
#3 glgrumpy OFFLINE
  • 8,494 Thanks
  • 7,850 posts
Posted March 16, 2017 - 01:52 PM
Never had on older rigs, but my newer Kohler V-twin will do that if I don't let it idle and I guess it cools some before shutting off. Hi speed just off, will make real ban g in a second, let it run at idle some and sometimes get varying bangs or None.  NO other issues involved, so good I guess!
  • boyscout862 and Xrperry have said thanks
#4 TAHOE ONLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted March 16, 2017 - 02:22 PM
My Tecumseh will do that if I drop it real quick, It's still sucking a lot of fuel while the timing is changing so it backfires. Probably similar to what you are getting.
  • Xrperry said thank you
#5 EricFromPa ONLINE
EricFromPa
  • 3,384 Thanks
  • 3,015 posts
Posted March 16, 2017 - 02:55 PM
What RPM are you shutting it off at? I hate seeing people shutting there machines off at higher rpms. It continues to pull fuel into the combustion chamber when you shut it off. Good way to wash out the rings. I Always shut my stuff off at idle and if I work the engine hard I'll let it cool down at idle for a bit before shutting it off.
Could be running a bit to lean or the muffler is to small for the engine. Is it running hot?
Edited by EricFromPa, March 16, 2017 - 02:57 PM.
  • Alc, KennyP and Xrperry have said thanks
#6 Xrperry OFFLINE
Xrperry
  • 971 Thanks
  • 740 posts
Posted March 16, 2017 - 07:36 PM
Thanks for responses everybody, well I shut it down at idle, the engine does not run hot,it runs almost perfect.that link tecumseh put on here has some causes,with that and the good people here I'll get it figured out. It's kinda funny,i shut it down, get off the machine,take a few steps, then POP.
#7 jimmy G ONLINE
jimmy G
  • 1,132 Thanks
  • 739 posts
Posted March 16, 2017 - 08:50 PM
Carbon in the muffler can work like a glow plug
#8 toppop52 ONLINE
toppop52
  • 4,905 Thanks
  • 4,559 posts
Posted March 17, 2017 - 11:15 AM
The Koehler single 20 hp on my straight will do it if I lower the throttle fast, and sometimes when shutting down. I cut mine off at high rpm and no pop.
#9 Sprint 6 OFFLINE
Sprint 6
  • 226 Thanks
  • 288 posts
Posted March 18, 2017 - 10:50 AM
Neither of my M/W 16's pop, but I have a fuel shut-offs on mine.  I turn the fuel off and let them idle to cool down until it stalls.  I credit this procedure with saving me from lots of carb clean outs.  Shut my Oliver Super 55 down the same way.  Have not had the carb apart on it in the 10 years I've owned it.
#10 Donald Mullett OFFLINE
Donald Mullett
  • 1 posts
Posted March 27, 2017 - 09:14 AM
Hello, I'm new at this old tractor stuff. I bought a M/W Gilson model 33420A and need to find the diagram for hooking up the hydraulic lift to the mower deck. Any help will be greatly appreciated. You can answer on here or message me on facebook.
#11 jimmy G ONLINE
jimmy G
  • 1,132 Thanks
  • 739 posts
Posted March 27, 2017 - 10:29 AM
Their is a manual section on this site,every thing you want is in it,if you have any problems just ask
