Rebuilding Deck
19 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,445 Thanks
  • 3,057 posts
Posted March 16, 2017 - 01:28 PM
Any tips on doing it? I bought the bearings awhile back but now I need to install them. It's a 42 " sears deck.
Edited by bbuckler, March 16, 2017 - 01:57 PM.
#2 glgrumpy ONLINE
  • 8,608 Thanks
  • 7,915 posts
Posted March 16, 2017 - 01:53 PM
Kinda vague on what we are working with ...SO......vague answer....Put them in! :smilewink:
#3 bbuckler ONLINE
bbuckler
  • 3,445 Thanks
  • 3,057 posts
Posted March 16, 2017 - 01:57 PM
I edited the post.
#4 MiCarl ONLINE
MiCarl
  • 2,024 Thanks
  • 1,050 posts
Posted March 16, 2017 - 02:00 PM
Sears made more than one 42" deck, I think.
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
If they are grease able bearings, make sure the open side is facing in. My 637 deck had them out and it sounds BAAAD. We replaced the bearings soon after we got it.
#6 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted March 16, 2017 - 02:17 PM
I think Larry rebuilt the deck on his Roper, if I remember, he had a grand old time getting it apart.
  • bbuckler said thank you
#7 boyscout862 OFFLINE
  • 12,843 Thanks
  • 9,166 posts
Posted March 16, 2017 - 02:26 PM
This is a great project to justify a press. Use the right press with safety equipment and it should be easy. PB Blaster and a little bit of torch are your friends. Good Luck, Rick
#8 EricFromPa ONLINE
EricFromPa
  • 3,657 Thanks
  • 3,112 posts
Posted March 16, 2017 - 03:05 PM
Yep your going to need a Press to get them back together or a chunk of heavy wall pipe that Just fits over the spindle shaft and a 3lb hammer lol.
Did you get new seals for them? Or do you plan on using sealed bearings and remove 1 seal on each bearing? I'm interested in what bearings and seals you got. The Seals I found for my 42" sears deck cost almost twice as much as the bearings. Luckily I only had to do the center spindles.
#9 bbuckler ONLINE
bbuckler
  • 3,445 Thanks
  • 3,057 posts
I went ahead and ordered new blades and idler pulley.
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,990 Thanks
  • 4,410 posts
Posted March 16, 2017 - 03:08 PM
Yep, broke my vice, and bent my bearing puller. Mine had 3 set screws each, several had to be drilled out. The pulley work starts here for your review. http://gardentractor...78-roper/page-8
  • boyscout862, TomLGT195 and bbuckler have said thanks
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted March 16, 2017 - 05:34 PM
  OA torch is your friend for this. Not for cutting, for heating. If the bolts that attach the mandrels to the deck are threaded in the mandrel, heat the area around each bolt and it will come out without twisting off. Heat the area around the pulley setscrews to get them loose. Don't be timid about using antiseize on all threaded components on reassembly. It might be you next time!!
                                              Mike
#12 bbuckler ONLINE
bbuckler
  • 3,445 Thanks
  • 3,057 posts
Posted March 16, 2017 - 07:31 PM
You are going to dislike me but all my set screws came out easy.
#13 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 6,990 Thanks
  • 4,410 posts
Posted March 16, 2017 - 08:08 PM
Cool deal. Still have to pull the pulleys and bearings. Keep us posted.
#14 bbuckler ONLINE
bbuckler
  • 3,445 Thanks
  • 3,057 posts
Posted March 16, 2017 - 08:09 PM
I will pull the pulleys tomorrow.
  • Bolens 1000 said thank you
#15 secondtry OFFLINE
secondtry
  • 1,882 Thanks
  • 1,380 posts
Posted March 16, 2017 - 08:49 PM
 Did you pull the set screws all the way out and check the holes. Some times people use 2 set screws in each hole, the second set screw just tight enough to keep the first from backing out. I started my deck rebuild last fall and got side tracked. Temps may get high enough to try painting again soon. Don
  • KennyP and bbuckler have said thanks
