Rover Rancher 2 with hillers / furrowers
3 replies to this topic
#1 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted March 16, 2017 - 06:18 AM
  • KennyP, boyscout862, propane1 and 3 others have said thanks
#2 KennyP ONLINE
  • 37,471 Thanks
  • 45,490 posts
Posted March 16, 2017 - 06:32 AM
Looks like it's working!
  • boyscout862 and holdenboy1960 have said thanks
#3 chieffan ONLINE
  • 9,574 Thanks
  • 6,412 posts
Posted March 16, 2017 - 09:19 AM
Working in loose ground but stops dead in it tracks when it gets into un-worked ground.  Might be OK for planting 5 A of potatoes except they should be planted on a ridge, not a furrow.
#4 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted March 17, 2017 - 04:05 AM
yes it does stop easily as i had no weights for traction at all , there is tree roots just under the sod in the middle where it snags them ,
i can remove the middle tine to spread the rows out if i want too as well , roughly 3 ft apart if needed or just use single tine if wanting too ,
the rear tires are 8 x19.50 x 8 so only small wheels , only use those tines to bust fresh soil , admittedly a little slow but works
Shane
