panzer mower deck
6 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 09, 2011 - 08:07 PM
well I put the mower deck on to the panzer 1107 today and got it all going exept for one small problem, The blades hit eachother. So I took the belt that spins both blades off and tried to set the right blade so it would not run into the other blade. I pu the belt back on and turned on the PTO. and they still hit. IDK what to do.
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted June 11, 2011 - 05:52 AM
is this a "timed" deck, or is it twisted/ wrong blades? I'm wondering if someone put the wrong blades under her... how much overlap on the hit?
#3 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,801 Thanks
  • 5,097 posts
Posted June 11, 2011 - 07:57 AM
That would be a timed deck. The blades have to be 1/4 of a turn from each other. If you are looking at the business side of the deck, one blade should be in the 12 o'clock/6 o'clock position. The other blade would have to be in the 3 o'clock/9 o'clock position. If you have put them in that position and they don't stay timed right, [get out of time and hit together] one of two things is going on. 1, one of the pulleys has been changed and is of a different diameter. you will need a new pulley. or 2, your belt has some of the cogs peeled off and allows slipping of the belt on the pulley. Good luck and hope that helped.
  • Bolens 1000, Encrypt, MH81 and 1 other said thanks
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 11, 2011 - 01:56 PM
well i solved the problem. I took out the angle grinder and took 1/4 in off of each side of each blade.
#5 Gtractor OFFLINE
Gtractor
  • 9,801 Thanks
  • 5,097 posts
Posted June 11, 2011 - 11:29 PM
What about that lil strip of grass right down the middle that doesn't get cut now?
:wallbanging:
#6 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 12, 2011 - 08:50 AM
they are know about 2 cm apart know so that little strip goes unnoticed
#7 Gtractor OFFLINE
Gtractor
  • 9,801 Thanks
  • 5,097 posts
Posted June 12, 2011 - 12:28 PM
Two cm is 13/16 of an inch!!!
:mecry:
