Belt issues
7 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 15, 2017 - 01:32 PM
Ok.im helping a friend who has a gt245 with a snow blower an it keeps eating belts all the pulleys are clean an no burrs an the belt does have some slack when installed what are we missing here? An it eats jd belts or gates belts.
Sent from my SM-S820L using Tapatalk
#2 lyall OFFLINE
lyall
  • 2,015 Thanks
  • 1,524 posts
Posted March 15, 2017 - 02:20 PM
how are the bearings in the idler pulley?
does the auger turn freely? if not check the auger bearings.
#3 propane1 ONLINE
propane1
  • 8,428 Thanks
  • 4,026 posts
Posted March 15, 2017 - 02:21 PM
Loose motor mounts. Just a guess. I'm having the same trouble with my lgt 165 ford and I think my motor mounts are bad causing the slipping belt.
Noel
#4 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 15, 2017 - 07:49 PM
He rebuilds old construction equipment so I'm sure everything else is good
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,777 Thanks
  • 9,918 posts
Posted March 15, 2017 - 09:23 PM
What's the model # on the blower? They made two different blowers in those years that will hook up to half the tractors they made, but they have about five different mounting systems that all look the same.
#6 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 16, 2017 - 05:33 AM
I'll post a picture of the tractor an blower numbers. His father in law bought them together from the local dealer
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,777 Thanks
  • 9,918 posts
Posted March 16, 2017 - 06:31 AM
Then that is most likely not the issue. I would check the back pins on the mounting arms to ensure they're fully engaged, check the alignment on the front bracket, (make sure nothing is bent) and then the two rear idler pulleys.
  • backwoods said thank you
#8 backwoods OFFLINE
backwoods
  • 2,617 Thanks
  • 2,814 posts
Posted March 16, 2017 - 06:56 AM
ok thanks cat
