Help with briggs choke linkage...
10 replies to this topic
#1 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted March 13, 2017 - 03:00 PM
So in the process of pulling the carb on my 11hp horizontal briggs, the damn choke linkage came off.
I just spent an hour trying to put it back togther and got pissed and walked from it.
Does anyone have an clear picture of how it hooks to the governor assembly?
I dont know what im missing here. If i put it on the way it looks like it should go on the spring does nothing and the throttle wont go down past half.
Help, im pulling my hair out.
#2 Bolens 1000 ONLINE
  • 14,902 Thanks
  • 18,101 posts
Posted March 13, 2017 - 03:16 PM
Whats the B&S model number?
#3 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted March 13, 2017 - 03:22 PM
252417 is the engine number...i cant find a number on the carb
#4 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted March 13, 2017 - 04:35 PM
They are all basically the same. If you take the choke cable, and hook it into the choke 'lever' then tighten it down to the carb you should be all good.
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,191 Thanks
  • 5,667 posts
Posted March 13, 2017 - 04:38 PM
Take a PEEK
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,971 Thanks
  • 9,615 posts
Posted March 13, 2017 - 05:06 PM
I usually make this mistake as well, but here's where I remind us again; take a photo of the linkage before we take it apart. :thumbs:
#7 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted March 13, 2017 - 05:43 PM
It doesnt have a seperate choke cable. Its intgrated with the throttle.
I watched that video but it didnt show what i needed.
  • 637Yeoman said thank you
#8 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted March 13, 2017 - 05:44 PM
Ah ok, well im of no help
#9 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted March 13, 2017 - 05:49 PM
Thanks anyways though.
#10 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted March 13, 2017 - 06:07 PM
for more info:
https://dl.dropboxus...linderLHead.pdf
  • DZG said thank you
#11 DZG OFFLINE
DZG
  • 607 Thanks
  • 525 posts
Posted March 13, 2017 - 07:02 PM
That manual really helped. My choke rod is a bit different (its got a much larger hook on the end) but its basically the same, i should be able to get it now. Thank you
