Where to hook up positive battery cable on Massey 12h
4 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,477 Thanks
  • 1,399 posts
Posted March 12, 2017 - 06:39 PM
Where do I hook up the positive battery cable on a Massey 12 hydro?
I have the one end figured out... on the positive post of the battery😂
Edited by Greasy6020, March 12, 2017 - 06:40 PM.
  • 637Yeoman said thank you
#2 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted March 12, 2017 - 06:54 PM
On the solenoid if it has one, or if it is a magneto ignition, the key switch.
  • 637Yeoman and Greasy6020 have said thanks
#3 chieffan OFFLINE
  • 10,164 Thanks
  • 6,642 posts
Posted March 13, 2017 - 07:25 AM
You better get a manual for your tractor and learn to read a electrical schematic.
  • boyscout862 and Greasy6020 have said thanks
#4 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,467 Thanks
  • 5,770 posts
Posted March 13, 2017 - 07:42 AM
One on the the Solenoid's big terminals..   Another small red wire also hooks up with it on that terminal.  (the primary power wire)  It usually goes to the key switch..
The other big terminal on the solenoid goes to the starter..
  • Greasy6020 said thank you
#5 boyscout862 ONLINE
  • 12,860 Thanks
  • 9,174 posts
Posted March 13, 2017 - 08:32 AM
Download the manual from our Manuals Section and study the wiring diagram. The cable usually goes from the positive terminal to a big lug on the starter solenoid. The other lug has a cable going to the starter. First thing to do is disconnect the ground cable from the battery. When working on a 12 volt battery system, always disconnect the ground cable before starting the work. When the work is done, connect the ground cable last. This will prevent accidental shorting out while working on it. Post some clear pics when you have questions. Good Luck, Rick
