Forklift Build-Option 2
home built fork lift
18 replies to this topic
#16 KennyP OFFLINE
  • 34,252 Thanks
  • 43,374 posts
Posted March 11, 2017 - 07:24 AM
Here's the link to the wheelchair lift.
  • Mark 149 J. said thank you
#17 MFDAC ONLINE
MFDAC
  • 2,791 Thanks
  • 1,423 posts
Posted March 16, 2017 - 07:39 PM
Thanks Don. Wasn't sure if that was feasible. I have some restricter fittings I could use. What kind of pressure does a Sundstrand make for the hydraulics?
Kenny I will follow along on this as a possible forklift had crossed my mind for my now unused MF8E. I have re-thunk that though and decided on a light-load front end loader or doing away with the hydraulics (power steering pump pressured) altogether and mounting a Sears Suburban mowing deck on it that I have out in a shed. The hydraulics currently operate the up and down on a dozer blade.
Anyway the reason I hijacked your thread was to see what these restricter fittings are that you and Don are speaking of. The power steering setup has always moved much faster than I would like and if this could work for a FEL, I would like it to operate much slower.
Thanks---DAC
#18 ducky OFFLINE
  • 1,961 Thanks
  • 4,085 posts
Posted March 16, 2017 - 10:35 PM
The restricter fittings are nothing more than a restriction to flow in the hydraulic lines.  They could be a fitting with a smaller hole or a washer under the fitting with a small hole to slow the flow of Hydraulic fluid.   They should not be used between the pump and return as it will cause the system to build too much heat.
  • KennyP and MFDAC have said thanks
#19 KennyP OFFLINE
  • 34,252 Thanks
  • 43,374 posts
Posted March 17, 2017 - 03:58 AM
Thanks---DAC
Look in this thread, post 28.
  • MFDAC said thank you
