First time - Valve seat reamer
25 replies to this topic
#16 bbuckler ONLINE
bbuckler
  • 3,195 Thanks
  • 2,877 posts
Posted March 15, 2017 - 06:31 PM
Leakdown test shows 30% now. Someone said there will be some leaking in the leakdown test and until they are ran. I don't feel the air on the intake side.
#17 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted March 15, 2017 - 06:50 PM
When you do your leak down test.
What position is the piston in?
#18 bbuckler ONLINE
bbuckler
  • 3,195 Thanks
  • 2,877 posts
Posted March 15, 2017 - 07:06 PM
TDC. Someone told me to try with some oil in the cylinder since the rings are new and it was down pass 20%.
#19 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted March 15, 2017 - 07:16 PM
NEEDS   to be TDC  in between compression and power strokes.
NOT   at TDC in between intake and exhaust strokes.
#20 bbuckler ONLINE
bbuckler
  • 3,195 Thanks
  • 2,877 posts
Posted March 15, 2017 - 07:17 PM
It is. I don't have the crank breather on right not which makes it easier to tell.
#21 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted March 15, 2017 - 07:21 PM
When you do your leak down test do both values has some lifter clearance?
#22 bbuckler ONLINE
bbuckler
  • 3,195 Thanks
  • 2,877 posts
Posted March 15, 2017 - 07:26 PM
yep. the intake could get grinded 0.01 off the stem
#23 DH1 ONLINE
DH1
    Electric Tractors
  • 5,136 Thanks
  • 5,521 posts
Posted March 15, 2017 - 07:41 PM
If you have clearance then there closed and should not leak.
#24 bbuckler ONLINE
bbuckler
  • 3,195 Thanks
  • 2,877 posts
Posted March 15, 2017 - 08:27 PM
it leaking around the new rings
#25 Dave in NY ONLINE
Dave in NY
  • 62 Thanks
  • 39 posts
Posted March 16, 2017 - 11:24 AM
You have done whats called a "3 angle valve job". Looks OK. Ought to work just fine.
#26 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,906 Thanks
  • 2,448 posts
Posted March 16, 2017 - 02:36 PM
Hopefully, the rings were installed properly on the piston and the ring gaps were staggered when installed in the cylinder.
