tune up kit
6 replies to this topic
#1 lrhredjb OFFLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted June 09, 2011 - 12:18 PM
I decided to post this in a separate thread from my brake question to avoid confusion. I seem to remember reading somewhere on the internet about a tune up kit for CC tractors. It included a spark plug, head gasket, maybe an air cleaner. I think it was referred to as a "restore the power", kit. Does something like this exist and is it less expensive than buying the parts per each? I noticed that the Kohler manual recommended cylinder head service every year. I have never had the head off this 106 in 15 years. Should I pull it now??
Larry
#2 chjr69 OFFLINE
chjr69
  • 5 Thanks
  • 13 posts
Posted June 09, 2011 - 01:17 PM
I don't know about the kit being cheaper but they did and I believe the still make them. As for the head gasket I pulled the head off a few times but I was already doing something to the motor, if it was not burning oil the head and piston were clean.
Good luck
#3 jhn9840 ONLINE
jhn9840
  • 436 Thanks
  • 385 posts
Posted June 09, 2011 - 02:01 PM
Personally I wouldn't pull the head unless there was some type of problem to justify doing so.
jhn9840
John
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted June 09, 2011 - 02:11 PM
I pernsonally would pull the head if it hasnt been off in many years. Its good to clean out the combustion chamber for added power and better fuel "yardige"
#5 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted June 09, 2011 - 04:14 PM
They also sell an ignition tune up kit for Kohler engines which has the spark plug, condenser, points and the push rod for the points. I think it is around $30 or so. It is a good idea to clean the carbon out of the head if it hasn't been done in a very long time as already suggested. As for the whole tune up kit I am not sure.
#6 loggerhenry OFFLINE
loggerhenry
  • 11 posts
Posted June 21, 2011 - 05:09 PM
i pulled the heads off of my 582. a mechanic that used to work on them told me to take them off every 150-200hrs to brush the carbon buildup in the dome and around the valves.
#7 lrhredjb OFFLINE
lrhredjb
  • 799 Thanks
  • 616 posts
Posted June 22, 2011 - 11:35 AM
Yeah, I guess I better plan on doing that soon. The trouble is I will want to repaint and do a lot of other work if I tear it down now and I don't like mowing with the push mower. Hmmm, that would be a good excuse to buy another CC.:smile1:
Larry
