Does it matter which way I put my wheels/tires on?
15 replies to this topic
#1 Mustard Tiger ONLINE
Mustard Tiger
  • 149 Thanks
  • 162 posts
Posted March 09, 2017 - 07:12 PM
The center part of the rims of the rear wheels is offset from the center by 2 or 3 inches.  So the way they are now the overall width is narrower, but there's less space between the rear tires.  If I flipped them around backwards I'd have a wider space between the tires.  Is that ok?  I'm not sure if the offset is specifically so that you can adjust the width this way, or if its because the weight of the tractor needs to be to the outside of the rims for some structural reason or something.
Also, with turf tires it doesn't matter which way the tread goes right?
  • MFDAC and pryan05 have said thanks
#2 BigFlash ONLINE
BigFlash
  • 248 Thanks
  • 134 posts
Posted March 09, 2017 - 07:24 PM
Are these bolt on wheesl? If so i would say which way you mount the wheels is all up to your preference or needs. That was often a simple feature of these older tractors.  If you run on lots of grades, run them wide for stability. If you have narrow area you need to fit in, run them narrow.
 If they are wheels that slide on a keyed shaft then i would say there is a specific way they go.
As for the turf tires. The only times I've seen tires that direction really mattered. They had arrows to designate the forward direction.
  • MFDAC, boyscout862, 637Yeoman and 2 others have said thanks
#3 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted March 09, 2017 - 07:26 PM
There is no structural reason to have them one way or the other.  The load is from the face of the hub straight down through the wheel either way.
What does matter is if the wheel is reversible.  There is a taper to the hole for the lug nut or bolt to seat into.  If the taper is on both sides you can reverse it.
If you switch the wheels side to side the tread will run the same direction they've been going but the stance will be wider.
** Didn't consider what BigFlash was posting.  I assumed bolt on wheels.
Edited by MiCarl, March 09, 2017 - 07:28 PM.
  • MFDAC, oldedeeres, 637Yeoman and 2 others have said thanks
#4 MFDAC OFFLINE
MFDAC
  • 3,592 Thanks
  • 1,710 posts
Posted March 09, 2017 - 08:54 PM
I reverse the wheels on my MF12G for the seasons. I like the narrow width during the mowing season to fit around trees and obstacles better. For snow plowing they must be set wider for the tire chains to fit without beating on the fenders. In this picture the right one is spaced out and left one is tucked in.
DAC
Edited by MFDAC, March 09, 2017 - 08:55 PM.
  • Alc, propane1, holdenboy1960 and 3 others have said thanks
#5 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted March 09, 2017 - 09:00 PM
the down side of reversing the wheels is the valve stem may be on the inside of the wheels. Trying to air up the tires in a mud hole with a box blade on the 3 point hitch can be frustrating
  • propane1, holdenboy1960, Mustard Tiger and 1 other said thanks
#6 propane1 ONLINE
propane1
  • 9,470 Thanks
  • 4,398 posts
Posted March 09, 2017 - 09:16 PM
They may need to be changed for ground plowing to line up the inner front and rear tires to be lined up for the furrow. And I agree with all the other posts.
Noel
  • MFDAC, Mustard Tiger and pryan05 have said thanks
#7 637Yeoman ONLINE
637Yeoman
  • 1,573 Thanks
  • 1,279 posts
Posted March 09, 2017 - 10:16 PM
Assuming its bolt on, its all personal preference. in the winter i run them narrow for storage
Edit: On my landlords i am unable to run both narrow, as the right tire hits the bgb
Edited by 637Yeoman, March 09, 2017 - 10:17 PM.
#8 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted March 09, 2017 - 10:17 PM
Have you tried airing up before you go in the mud hole?
  • KC9KAS, holdenboy1960, 637Yeoman and 1 other said thanks
#9 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted March 09, 2017 - 10:59 PM
I dont have room to keep them all inside. It usually works out that the one I need to use has a flat tire right after it rains
Edited by tater195, March 10, 2017 - 07:46 PM.
  • 637Yeoman and pryan05 have said thanks
#10 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,468 Thanks
  • 4,582 posts
Posted March 10, 2017 - 01:45 PM
I'll tackle the tread pattern, Turf's doesn't matter, All Terrain doesn't matter except for looks, Chevron's does matter, You will be remounting one if backwards, and I have been there and done that!
Edited by larrybl, March 10, 2017 - 01:46 PM.
  • holdenboy1960, 637Yeoman and Mustard Tiger have said thanks
#11 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,125 posts
Posted March 10, 2017 - 04:00 PM
If he's got chevrons swapping the left and right wheels will keep them running the correct direction.
  • larrybl, propane1, Leonard VanCamp and 1 other said thanks
#12 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,468 Thanks
  • 4,582 posts
Posted March 10, 2017 - 05:51 PM
Yep, then it would look like MFDAC's, One sticking out futher than the other. :rolling:
  • MFDAC said thank you
#13 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,130 Thanks
  • 10,198 posts
Posted March 10, 2017 - 06:31 PM
I usually put the right one on first and then the left.
#14 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted March 10, 2017 - 06:41 PM
That's your shoes,bud!
  • EricR said thank you
#15 MFDAC OFFLINE
MFDAC
  • 3,592 Thanks
  • 1,710 posts
Posted March 10, 2017 - 08:55 PM
That's my oval track setup to gain left-side weight bias----
DAC
  • larrybl said thank you
