Brakes for Cub Cadet 106
10 replies to this topic
#1 lrhredjb OFFLINE
lrhredjb
  • 656 Thanks
  • 547 posts
Posted June 09, 2011 - 12:09 PM
Hi There,
I have a CC106 that is in need of some brake work. Has anyone ever found an alternative to the $$ pads sold by the dealer? I often wondered why they couldn't be relined like clutch
plates.
Larry
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted June 09, 2011 - 04:48 PM
Hi There,
plates.
Larry
If you can get the materials I don't think there is any reason why you couldn't reline the pads yourself. I have never done it. You could also get a used set, it's not too often that the brake pads get worn out.
#3 ad356 OFFLINE
ad356
  • 9 Thanks
  • 160 posts
Posted June 11, 2011 - 12:00 PM
my pads on my 147 are a little worn. there is still meat there but not enough for the brakes to fully close. i shimmed it out with washers, works great. those dealer item brake pads are for the "birds", 150 bucks a side? what are they thinking, thats just as bad as 250 bucks for a gas tank.
#4 EricFromPa ONLINE
EricFromPa
  • 3,513 Thanks
  • 3,064 posts
Posted June 11, 2011 - 12:07 PM
Here check this out.
Brake Pads for Cub Cadet or John Deere Lawn Tractors | eBay
You can reline them for around $50.00
#5 KennyP OFFLINE
  • 37,398 Thanks
  • 45,448 posts
Posted June 12, 2011 - 04:59 AM
I just uploaded a .pdf to the Cub manuals thread for a brake reline on a 149. If yours are similar, you can use it. Pretty informative and cost is minimal.
#6 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted June 12, 2011 - 07:10 PM
The other option which many of the Cub guys do is this.
McMaster-Carr
Get yourself a length of this material and reline your old ones yourself. About the cheapest route you can go I think.
  • olcowhand and MH81 have said thanks
#7 KennyP OFFLINE
  • 37,398 Thanks
  • 45,448 posts
Posted June 13, 2011 - 06:11 AM
McMaster-Carr
That is what is used in the .pdf I uploaded. Explains the whole process of prep, gluing, and such.
#8 IHCubGuy OFFLINE
IHCubGuy
  • 1,500 Thanks
  • 1,579 posts
Posted June 13, 2011 - 07:25 PM
Sorry, I never looked at the upload you mentioned before I made my post. Guess my fingers got ahead of my brain.
#9 KennyP OFFLINE
  • 37,398 Thanks
  • 45,448 posts
Posted June 14, 2011 - 03:07 AM
No problem. I do that a lot.
#10 lrhredjb OFFLINE
lrhredjb
  • 656 Thanks
  • 547 posts
Posted June 14, 2011 - 07:26 AM
I was thinking of using one of my old IN license plates to cut out a shim. It's flat aluminum and my bandsaw would make quick work of it.
Larry
#11 KennyP OFFLINE
  • 37,398 Thanks
  • 45,448 posts
Posted June 14, 2011 - 05:04 PM
Following the instructions in the .pdf I uploaded, you might be out around $20 or so for new brakes.
