Bolens HT 23
4 replies to this topic
#1 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,545 Thanks
  • 961 posts
Posted March 08, 2017 - 06:26 PM
If it wasn't for that plastic dash... :(
Seriously kinda like it, engine in gray primer may be a factory replacement,states snowblower ,see brackets for 2 stage springs... unusual for that late of a model to have the sundial hour meter,(if it is a '87) hood scoop and cowl induction fan probably good for 2-3 more mph, it may give a HDT1000 a run, if it was closer... more I look at it the more I like it...Seriously
http://www.ebay.com/...qIAAOSwr~lYrHmS
  • blackjackjakexxix, boyscout862, bprzyw and 1 other said thanks
#2 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted March 08, 2017 - 06:46 PM
Looks good!
Paint doesn't make the engine, or tractor worth more. The scoop is for the electric fan added, and personally, I wouldn't buy it.
Power steering is a +
  • WrenchinOnIt and boyscout862 have said thanks
#3 boyscout862 ONLINE
  • 12,517 Thanks
  • 9,028 posts
Posted March 08, 2017 - 08:48 PM
The plastic dash on my HT23 is all busted up. I plan to adapt an aluminum dash from a 1050 parts tractor that I have. It looks the same size. Good Luck, Rick
  • WrenchinOnIt said thank you
#4 1oldbuzz OFFLINE
1oldbuzz
  • 541 Thanks
  • 435 posts
Posted March 09, 2017 - 05:46 AM
I would question the addition of the electric fan
I don't see it providing any benefit the way is mounted
I would think if you have cleaned  the shrouds,engine fins
and flywheel fins it should cool just fine
  • boyscout862 and Leonard VanCamp have said thanks
#5 Sprint 6 OFFLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted March 09, 2017 - 07:25 AM
What's the point in the electric fan?  Looks like to me, it would actually impede cooling.  The flywheel is blowing air in the front, and it would rise up and out of the shroud.  If that fan is blowing down, it is going to blow the heated air right back down on the engine.  If it is setup to pull, that would be slightly beneficial, but it is going to bake the operator in the summer.
