Spike Tooth Harrow Help
11 replies to this topic
#1 Zekkjacen OFFLINE
Zekkjacen
  • 160 Thanks
  • 195 posts
Posted March 07, 2017 - 07:20 PM
I have a spike tooth harrow I'm fixing and fixing up. From the picture is it obvious what they wanted to use it for.  I'm wanting if for my DB however.  Could someone provide me with the length of the hitch arm?  It would be easier than trial and error.
#2 Zekkjacen OFFLINE
Zekkjacen
  • 160 Thanks
  • 195 posts
Posted March 07, 2017 - 07:23 PM
I don't know what these are supposed to be painted, but I'm going with  IH-Red.
#3 Zekkjacen OFFLINE
Zekkjacen
  • 160 Thanks
  • 195 posts
Posted March 07, 2017 - 07:24 PM
Also, is it typical to see this cast piece cracked?  Should I worry about fixing it?
#4 637Yeoman OFFLINE
637Yeoman
  • 1,690 Thanks
  • 1,362 posts
Posted March 07, 2017 - 09:09 PM
i wouldnt but thats just me
  • Zekkjacen said thank you
#5 Alc ONLINE
  • 7,349 Thanks
  • 7,633 posts
Posted March 07, 2017 - 09:12 PM
I'll try to remember to get you that size tomorrow .
#6 Zekkjacen OFFLINE
Zekkjacen
  • 160 Thanks
  • 195 posts
Posted March 07, 2017 - 09:18 PM
I do plan to use these as they were intended, but I also want to take care of them (DB + Attachments in general).  I'm not looking for museum looking/quality, but I do want solid functional quality and I want to complete them as original (function and looks) as possible.
Thanks!
  • Alc and 637Yeoman have said thanks
#7 propane1 ONLINE
propane1
  • 9,733 Thanks
  • 4,513 posts
Posted March 07, 2017 - 09:41 PM
If the cracked piece has pressure on it when using it, I would get it fixed. If the cracked piece breaks and you lose the piece, it will be much harder to repair and keep original looking. Just my opinion.
Noel
  • MH81 and Zekkjacen have said thanks
#8 Alc ONLINE
  • 7,349 Thanks
  • 7,633 posts
Posted March 08, 2017 - 11:52 AM
From the vertical flat plate which the roller is attached to to edge of the hitch pin is 29" holding the tape at the bottom of the pin to a few inches up on the vertical plate that's about straight across
#9 Zekkjacen OFFLINE
Zekkjacen
  • 160 Thanks
  • 195 posts
Posted March 10, 2017 - 04:45 PM
Thank you! I'll see where I get and keep you posted!
#10 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted March 11, 2017 - 09:17 AM
I have a DB walk behind spike tooth drag I'll post some pics in a little while
#11 Mudwallower OFFLINE
Mudwallower
  • 24 Thanks
  • 27 posts
Posted June 30, 2017 - 04:11 PM
Could you post those images???
Edited by Mudwallower, June 30, 2017 - 04:12 PM.
#12 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted July 02, 2017 - 06:20 AM
Here are some pictures of mine
Edited by drbish, July 02, 2017 - 06:23 AM.
  • CRFarnsworth and Mudwallower have said thanks
