sears suburban plow blade
10 replies to this topic
#1 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted March 07, 2017 - 01:31 PM
I have a question, on my snow plow mount,in the back,on top of the mule drive looking part is a big bolt. anybody know what its for? also does the mount lock into place when you slide it into the tractor? mine seems to have a lot of up, down slop. the little pins on the side of the mount were wore so I welded them up, ground them back to where they were when it was new. that helped a bunch, it seems like I can pull the blade mount out quite a ways.the pins on mount are almost at the end of the tractor frame.
Edited by Xrperry, March 07, 2017 - 01:33 PM.
#2 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted March 07, 2017 - 03:21 PM
The blade should be held in place with the bars going to the front axle tabs.
Edited by TAHOE, March 07, 2017 - 03:21 PM.
  • MH81 and Xrperry have said thanks
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted March 07, 2017 - 06:59 PM
Some of them like the one I have takes to short bolts in the front of the mule drive. There is a slot in the plow mount . I have the speed hitch one you don't see them too often. Yours may take bolts in the slots also. Then my plow goes on that backing plate with two pins
  • Xrperry said thank you
#4 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted March 07, 2017 - 07:01 PM
If you zoom in and look under the lower grille you'll see a bolt in the one side of the mule drive .
#5 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted March 07, 2017 - 09:46 PM
Yeah it's different than mine tecumseh. I am still farting around with the blade digging in when it is turned to extreme left and right.when the blade is on the floor turned extreme left or right there is about a 2 inch difference from one corner to the other. I don't remember it doing this early in the winter, it does now and drives me frigging nuts.the blade sits flat all the way across when it is straight ahead
  • Tecumseh power said thank you
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted March 07, 2017 - 11:12 PM
Can you send or post me a picture of the mount and the mule drive
#7 Xrperry OFFLINE
Xrperry
  • 1259 Thanks
  • 876 posts
Posted March 08, 2017 - 10:31 AM
il do that Tecumseh thanks!
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted March 08, 2017 - 06:33 PM
I'll get you a close up of my bolts too because yours probably has those slots also
#9 Tecumseh power OFFLINE
Tecumseh power
  • 1535 Thanks
  • 1133 posts
Posted March 08, 2017 - 07:27 PM
Yours may take the bolts also , have to see the pics, I had another style mount that did. And two bolts to the axle.
Edited by Tecumseh power, March 08, 2017 - 07:30 PM.
#10 Walkinman1 OFFLINE
Walkinman1
  • 773 Thanks
  • 599 posts
Posted April 29, 2017 - 05:03 PM
Were you ever able to get this figured out? Mine has two extra bars that I believe were made by the previous owner, yours might need something similar...
Sent from my XT1254 using Tapatalk
#11 Buck Tales OFFLINE
Buck Tales
  • 232 Thanks
  • 142 posts
Posted May 26, 2017 - 08:48 AM
Here's a couple of picks of one of mine that shows the bars and the slide plate. bars definitely go to the front axle tabs.
