speedex 1140
4 replies to this topic
#1 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted March 06, 2017 - 07:36 PM
tractor is for sale but it is stuck in 1st gear. easy fix?????
#2 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted March 06, 2017 - 08:08 PM
Need more info. This a trans-axle or 3spd BW or something else?  Borg-warners are known to lock up when shift lever ball end wears and drops between two gears on shafts.  Can remove top of trans and reposition forks and set back on to see if works.  May work after or may just jamb again when using. Easy fix building up the end of shaft with weld and shaping. See the Power King group here for that info. IF, a trans-axle, still might be shifter wear, but think you would be looking into more tear-down to find exact problem. How about a pix of this one.  I'm not familier with model. Have had 1040, not 11. Briggs?
Was just re-thinking.....the 4 in model should mean it is 4 spd and is thusly a trans-axle if I recall. Would need a little more exploring to fix that I belive. What's the price on this?  Would have to be cheap for me to buy, but I"M cheap anyway, heh!
#3 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 150 posts
Posted March 06, 2017 - 08:17 PM
https://buffalo.crai...6032316224.html
#4 MiCarl ONLINE
MiCarl
  • 2,207 Thanks
  • 1,124 posts
Posted March 06, 2017 - 09:49 PM
The implements are probably worth at least $300.  Not sticking your neck out much on the package at $400.
  • karel said thank you
#5 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted March 07, 2017 - 07:12 AM
Yeah, don't look too bad. Think it's worth that with rest of stuff.
