wards tiller shaft to short
3 replies to this topic
#1 Casinojim ONLINE
Casinojim
  • 123 Thanks
  • 157 posts
Posted March 06, 2017 - 04:48 PM
I took off my front blade to put my tiller on this weekend and it snowed both days  :(  but found out the shaft is to short maybe 5 1/2 inches this is the first time putting on a tiller are there other longer and the tiller mounts in the middle of the back hitch?KIMG0180 (1).jpg IMAG0332.jpg IMAG0334.jpg IMAG0336.jpg IMAG0341.jpg IMAG0342.jpg IMAG0346.jpg IMAG0347.jpg
#2 Sprint 6 OFFLINE
Sprint 6
  • 227 Thanks
  • 293 posts
Posted March 06, 2017 - 07:00 PM
You have a tiller PTO setup from an earlier, Gilson S series, based machine.  The later tractors use the same mountings front and rear, but the rear hitch is further rearward than the earlier tractors, making the PTO shaft and lift rods too short.  You will either have to lengthen the shaft, or find the PTO for a later tractor.
#3 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted March 06, 2017 - 07:26 PM
Seems like my luck! i take off the plow, and wouldnt you know it, it snows a foot. :mad2:
#4 Casinojim ONLINE
Casinojim
  • 123 Thanks
  • 157 posts
Posted March 06, 2017 - 08:42 PM
can someone tell me how much longer the shaft and the lift rod are, compared to the ones i have. i did not measure the shaft just the lift rod looked like 5 1/4 inches to short.   gone try again this weekend IF its not snowing! :wallbanging:
