Eaton and Sunstrand hydro pump question
7 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted March 06, 2017 - 06:01 AM
Wanting to know if the input shaft bearing on these pumps will take
side load
I am wanting to run a belt drive with engine mounted
directly over the rear end
#2 dropped82 ONLINE
dropped82
    Nut Case
  • 2,504 Thanks
  • 1,820 posts
Posted March 06, 2017 - 06:26 AM
There are applications out there that use these pumps with a belt drive. The simplicity and Allis Chalmers tractors are an example. They use a Sundstrand pump belt driven from the bgb. I'm not sure on bearing differences.
Eric
Edited by dropped82, March 06, 2017 - 06:27 AM.
  • Alc, Sawdust and 1oldbuzz have said thanks
#3 GWest OFFLINE
GWest
  • 548 Thanks
  • 499 posts
Posted March 06, 2017 - 06:46 AM
Most of the Wheel Horses are belt driven and the GT-14's used a double pulley on the hydro pump to drive the rear tiller.
The D-Series Auto models used a shaft driven pump.
Garry
  • Alc and 1oldbuzz have said thanks
#4 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted March 06, 2017 - 07:14 AM
Ok here's my idea/plan
I am thinking of building an articulated machine
I want to mount an engine directly over the rear end /transaxle
and drive the pump via belt or chain
Mini wheel loader so to speak
#5 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted March 06, 2017 - 07:19 AM
I know you can tell on the Eaton's if they have a bushing or a bearing in the charge pump. Not sure about the Sundstrand. I would think a bearing would be better for this. I'll be lurking as I have a Sundstrand I would like to change how it's driven. A direct drive shaft would be in the way of things.
  • 1oldbuzz said thank you
#6 1oldbuzz OFFLINE
1oldbuzz
  • 568 Thanks
  • 450 posts
Posted March 06, 2017 - 07:34 AM
My thoughts are to keep all the weight over the rear axle
also didn't want to over complicate with a multi joint drive shaft
something similar to this
this machine is way over complicated using
multipal pumps and a vw tranny/transaxle
and needs a lot of refabing
#7 chieffan ONLINE
  • 10,201 Thanks
  • 6,662 posts
Posted March 06, 2017 - 08:06 AM
Don't know why if wouldn't work.  I would go with a roller chain as you have a lot less side pressure with a chain drive.  As Kenny siad, make sure you have a bearing and not a bushing.
#8 glenford7502 OFFLINE
glenford7502
  • 102 Thanks
  • 72 posts
Posted March 17, 2017 - 05:26 PM
If you are concerned on side loading the shaft build a carrier bearing on the other side of the pulley to support some of the load.
