Who thinks it will or won't run?
13 replies to this topic
  • 2,325 Thanks
  • 1,496 posts
Posted March 05, 2017 - 07:43 PM
Awhile back I mentioned I needed a replacement engine for my 5hp tiller. It needed to be dual shaft.  I had to choose between a Briggs 4 hp dual shaft with a badly scored cylinder (100292 ...) and a Briggs 5hp gear reduction engine (130252 ... ) with a stuck valve & a slightly scored cylinder.
I went with the 5hp, but stole the crank, cam shaft, etc from the 4hp engine.  I had to keep the old connecting rod because the wrist pin was smaller on the 4hp engine.  The problem is that the 4hp had a shorter crankshaft throw &/or the 5Hp connecting rod is shorter. Either way, the piston stops 1/4" from the top.
Hence, the question: will it run?
I have honed the cylinder, but it is about .003" over with a stock piston and reused the rings that are just in or just out of spec.  I lapped the valves while I had it a part. I haven't done a compression test yet, just to keep the guessing interesting.  I do have spark.
  • stiemmy, holdenboy1960 and pryan05 have said thanks
#2 pryan05 OFFLINE
pryan05
    LGT
  • 618 Thanks
  • 342 posts
Posted March 05, 2017 - 07:59 PM
Yes!  Post a video of the first time you start it!
#3 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,129 Thanks
  • 4,893 posts
Posted March 05, 2017 - 08:21 PM
It'll run fine but it'll have less than 4 horsepower because of the lower compression
  • boyscout862, New.Canadian.DB.Owner and holdenboy1960 have said thanks
#4 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted March 05, 2017 - 08:23 PM
I don't think it will have enough power to operate the tiller if it runs.
  • New.Canadian.DB.Owner and holdenboy1960 have said thanks
#5 chieffan OFFLINE
  • 9,609 Thanks
  • 6,427 posts
Posted March 05, 2017 - 08:25 PM
Should run but will be short of pulling or lugging power.  Might have to spin it over faster to get it going.
#6 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted March 05, 2017 - 08:46 PM
It should run, but we'll see. Some old flatheads ran @, 6:1, or right around there for compression. The real question is, how much power is it gonna make?
You could mess with deck height, or mill the head, and or thin head gasket to raise the compression, but, you have to keep an eye on valve clearance to the head, and personally I dont believe these mods are going to make a big difference imo.
Edited by stiemmy, March 05, 2017 - 09:07 PM.
#7 EricFromPa OFFLINE
EricFromPa
  • 3,527 Thanks
  • 3,071 posts
Posted March 05, 2017 - 08:52 PM
It will run.
Power? it's gona be lacking a bit. But it might have enough to use the tiller if you go slow.
True story here.The K181 in my Cub Cadet 70 was smoking a good bit so I pulled it apart.What I found wrong with it is just Nuts.It had been bored .010 over and crank turned .010 under.That's all good.But someone stuck a K161 rod and piston in it.Rod is 1/4" shorter.But it ran OK just a little down on power.It would struggle with the 38" deck set down to 1".
It had a couple other problems that are much much worse though.Glad I bought that spare block for it.I'm gona need it.
Edited by EricFromPa, March 05, 2017 - 08:53 PM.
#8 secondtry OFFLINE
secondtry
  • 1,688 Thanks
  • 1,288 posts
Posted March 05, 2017 - 09:41 PM
I would say that unless you are used to running that machine in good condition you won't even notice. Don
#9 karel ONLINE
karel
  • 1,991 Thanks
  • 1,334 posts
Posted March 05, 2017 - 11:39 PM
shoulda went with new rings
#10 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted March 06, 2017 - 04:05 AM
it will run but be down in compression and power torque , only be light application engine , and don't hard ( over ) revv it
Shane
#11 karel ONLINE
karel
  • 1,991 Thanks
  • 1,334 posts
Posted March 06, 2017 - 09:19 AM
Shane
That's why I said, shudda went with new rings. Woulda been a whole different animal if he shaved the head to.
  • New.Canadian.DB.Owner, holdenboy1960 and 29 Chev have said thanks
#12 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 8,079 Thanks
  • 2,667 posts
Posted March 06, 2017 - 07:15 PM
If you honed the cylinder wall and then did not use new rings the engine will probably smoke and use oil as the rings will probably never seat again.
  • New.Canadian.DB.Owner, karel and holdenboy1960 have said thanks
#13 dodge trucker ONLINE
dodge trucker
  • 2,307 Thanks
  • 3,020 posts
Posted March 07, 2017 - 07:21 PM
if it runs with the piston down in the hole that far it will be a complete turd. not enough power to run that machine in the dirt, for sure.
  • New.Canadian.DB.Owner, holdenboy1960 and nitro have said thanks
#14 nitro OFFLINE
nitro
  • 170 Thanks
  • 113 posts
Posted March 08, 2017 - 05:32 AM
Brings me to mind of the '79 Malibu 267 I had once.  No compression, no balls.
  • Alc, New.Canadian.DB.Owner, dodge trucker and 1 other said thanks
