Found a Vintage "Brush King" Saw/weed cutter?
2 replies to this topic
#1 Bolens 1000 OFFLINE
  • 15,139 Thanks
  • 18,188 posts
Posted March 05, 2017 - 11:56 AM
Picked this up yesterday , was going to the scrap yard so for $15 couldnt resist. Originally I wanted the air cleaner and recoil off it as they will fit my Bolens saw but dont want to take apart this machine until I know more about it and I'm not destroying a collectable item.
Cant find much online about them
  • wilberj, Gtractor, Alc and 4 others have said thanks
#2 Gtractor OFFLINE
    the homeless tractor hoarder
  • 9,485 Thanks
  • 5,001 posts
Posted March 05, 2017 - 12:59 PM
I have 2 newer versions with the 3 horse, 2 cycle Tecumseh.  Used to use it a lot to cut trails on FIL's hunting farm.  The one I used had a 3-prong saw blade and it would glide right through saplings.  Mine are the curved shaft - I see yours is straight shaft.
Tore my back up at work in '06 so I know its not been started since then.
We called it the "Man Killer" and that's when I had a good back!
I also have the post hole digger version and the string trimmer version on a framework with one wheel.   All have the 2-stroke Tecumseh.
  • Bolens 1000 said thank you
#3 drbish ONLINE
  • 1,570 Thanks
  • 1,369 posts
Posted March 05, 2017 - 02:04 PM
I found this on the stak
