NOS Tecumseh push mower battery!
6 replies to this topic
#1 Bolens 1000 ONLINE
  • 14,888 Thanks
  • 18,096 posts
Posted March 04, 2017 - 04:26 PM
What are the odds of this NOS battery being good?
Got to be late 70's early 80's from the packaging
This should fit my Toro Guardian :D
  • Traill95, boyscout862, stiemmy and 1 other said thanks
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,464 Thanks
  • 1,104 posts
Posted March 04, 2017 - 04:50 PM
Do you have to add acid? Or already in it?
#3 Bolens 1000 ONLINE
  • 14,888 Thanks
  • 18,096 posts
Posted March 04, 2017 - 04:59 PM
Instructions say "Nickel Candium" battery no maintenance so I assume everything was pre set, but I doubt they originally shipped these charged?
#4 DougT ONLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted March 04, 2017 - 05:05 PM
It wouldn't surprise me if they were shipped charged. Isn't nickel cadmium the same as what they used in flashlight batteries like AA, C, D that were rechargeable? They came with an initial charge.
  • Bolens 1000 said thank you
#5 Bolens 1000 ONLINE
  • 14,888 Thanks
  • 18,096 posts
Posted March 04, 2017 - 05:13 PM
That I'm not sure of, Electrical stuff is my weakness
#6 DougT ONLINE
DougT
    Dog Approved
  • 6,846 Thanks
  • 4,948 posts
Posted March 04, 2017 - 05:23 PM
Here's what Wikipedia has to say about it.  https://en.wikipedia...cadmium_battery   I didn't realize they were considered a wet cell battery. Do you have the charger for it? Measure DC volts across the terminals. Does it show anything?
  • Bolens 1000 and 637Yeoman have said thanks
#7 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted March 04, 2017 - 08:12 PM
I believe the Toro Guardian battery mounted to the underside of the top handle plate.  ...The battery case was a different shape than the battery in your pic.
I'm not sure, but I may have a battery case for the Guardian (I used one in an alarm system I built).  .....The Toro battery had a red plastic housing with an aluminum cover held on with 2 Phillips flat-head screws.  ....The Ni-Cad cells could be replaced individually if necessary, but they were not available through Toro or Tecumseh.  ....My memory thinks there were 6 cells inside the housing.
