What I finally bought with my Christmas money!
drill press
11 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted March 03, 2017 - 12:01 AM
I finally found what I wanted for Christmas!  I had been looking for a floor model drill press for quiet sometime and never found what I wanted until today.  It's older but it is built very well.  It has a 220 volt 3/4 hp motor, 12 speeds, 5/8 chuck, and a very large table that can be removed it needed.  It's not the best looking but boy does it have a lot of power!
20170302_203107.jpg 20170302_203132.jpg 20170302_203138.jpg 20170302_203155.jpg 20170302_203159.jpg
  • Gtractor, grnspot110, hamman and 9 others have said thanks
#2 Cvans ONLINE
  • 5,774 Thanks
  • 5,734 posts
Posted March 03, 2017 - 12:25 AM
Good for you. Nothing like a good drill press to get the job done right. I ended up putting a 3/4 hp. motor on mine and it made a big difference.
They make a jig for centering round objects like pipe and shaft under the drill bit. They are a really good accessory.
http://www.ebay.com/...725.m3641.l6368
  • hamman, KennyP, boyscout862 and 3 others have said thanks
#3 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted March 03, 2017 - 12:31 AM
It's just like Tim the Tool Man Taylor said you always need "more power".  Not that long ago somebody (I think it was Kenny) had made a centering jig for drilling tubing.  I was going to make mine own.
  • KennyP and holdenboy1960 have said thanks
#4 Kster526 ONLINE
Kster526
  • 590 Thanks
  • 369 posts
Posted March 03, 2017 - 04:51 AM
Nice find been wanting one myself just have not found the right one. May want to consider
rounding the edges a bit on the table though. It'll save curse words or stitches later.
The. voice of experience or bad karma coming thru.
  • KennyP and Mark 149 J. have said thanks
#5 KennyP ONLINE
  • 34,189 Thanks
  • 43,310 posts
Posted March 03, 2017 - 04:53 AM
That was to weld two lengths of round stock, but I guess it could be used for this too.
#6 John Arsenault OFFLINE
John Arsenault
  • 1,479 Thanks
  • 809 posts
Posted March 03, 2017 - 06:53 AM
Guess you didn't know that you were making a multi-tool....lol
#7 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted March 03, 2017 - 09:59 AM
I agree!  I already experienced that while I was moving it. :wallbanging:
#8 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted March 03, 2017 - 10:03 AM
Kenny,
See what you started!.  The next great multi-tool.  You can call it the KennyJig :rolling:
Kind of sounds like a dance. :dancingbanana:
  • KennyP, LilysDad and holdenboy1960 have said thanks
#9 LilysDad ONLINE
LilysDad
    Oh, shoot!!!
  • 11,789 Thanks
  • 8,919 posts
Posted March 03, 2017 - 01:41 PM
3/4 horse power drill - I sure don't want to be there when the bit catches breaking through the hole. :thumbs:
  • Gtractor and Mark 149 J. have said thanks
#10 Bill 76 OFFLINE
Bill 76
  • 1,830 Thanks
  • 1,146 posts
Posted March 03, 2017 - 03:20 PM
Nice drill press , made in Taiwan , much better than Chinese stuff.
I see it has a #2 morse taper on the spindle , you can drill up to about 7/8 inch with that taper . Lots of morse taper shank drills on ebay . Just make sure to run it at the slowest speed with large drills and clamp down the work piece.
  • Mark 149 J. said thank you
#11 jhn9840 ONLINE
jhn9840
  • 266 Thanks
  • 277 posts
Posted March 03, 2017 - 10:00 PM
Nice piece of old iron. Enjoy your Christmas present .
jhn9840
John
#12 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,487 Thanks
  • 915 posts
Posted March 08, 2017 - 12:54 AM
I finally got some time to try out my new drill press tonight.  I started off by using a 1/2 drill bit and then moved up to a 15/16 bit.
This drill didn't even break a sweat.  It slowed down but never stopped or even make the belt squeal.  My old drill would have taken 3 times longer and would have made a lot more noise.  So far I'm really happen with it.  The only problem that I've found so far is the return spring is broken.  Not a big problem because even with a big bit it doesn't slide down on its own.
I drilled into an old rotor from my car.  The yellow marks indicate which holes I drilled.
  • KennyP, EricR and holdenboy1960 have said thanks
Also tagged with one or more of these keywords: drill, press
