New Toys
10 replies to this topic
#1 MGP59DB OFFLINE
MGP59DB
  • 1,486 Thanks
  • 710 posts
Posted March 02, 2017 - 08:10 AM
I have been wanting one of these for awhile , I finally pulled the trigger .(pun intended)
1/2 Drive Electric Impact , and 37 piece sockets
Last summer when working on my truck my uncle brought his over and it was great for removing the tires and other stubborn things.
Yes -it is not the best quality , But It was on special at Harbor Freight for a very good price.
On another note I was watching an online auction nearby and was keeping an eye on this generator .
8HP B&S  Coleman 4000watt 120/240
I couldn't resist when I was able to pick it up for less than $50 . I had been there and looked it over yesterday . Clean tank had compression and hot spark . If nothing else It has parts on it that are worth more than I paid for the whole thing.
I think it will be a good runner and hope the thing works , you never can tell . I know the motor will run .
Edited by MGP59DB, March 02, 2017 - 08:25 AM.
  • Gtractor, Alc, hamman and 4 others have said thanks
#2 chieffan OFFLINE
  • 8,799 Thanks
  • 6,034 posts
Posted March 02, 2017 - 08:37 AM
You will wonder how you got along without that impact.  I have a 1/2" and 1/4" DeWalt and they are my go to impact drivers.
  • hamman, boyscout862 and MGP59DB have said thanks
#3 KennyP ONLINE
  • 35,073 Thanks
  • 44,100 posts
Posted March 02, 2017 - 08:41 AM
Nice additions to the tool box.
  • boyscout862 and MGP59DB have said thanks
#4 boyscout862 OFFLINE
  • 11,838 Thanks
  • 8,680 posts
Posted March 02, 2017 - 08:48 AM
Nice acquisitions. Those generators have two possible problems that are easily fixed and several that aren't. The early generators used a standard grease in the outboard bearing. I've found many that they just needed their brushes and commutator cleaned. I used carb cleanner and qtips to do the job. The second easy fix is to excite the field. With the generator running, plug in a variable speed drill. Pull the trigger. If the drill doesn't spin, grab the chuck and give it a spin. This will usually create just enough current to activate the field and make the generator work again. The drill will take off so, be carefull. I've also had to replace diodes but I don't know where to get the correct ones any more. Sometimes the field is burned out because the user just drew too much amps. Good Luck, Rick
BTW For everyone with a good engine and bad generator, I've found a good generator with a blown engine. People don't put oil in their new engines.
Edited by boyscout862, March 02, 2017 - 08:52 AM.
  • KennyP and MGP59DB have said thanks
#5 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,187 Thanks
  • 2,781 posts
Posted March 02, 2017 - 11:25 AM
Let us know how that works. I have been looking at it and wondered how it will do. I mainly want it to keep in my truck for the use of removing and replacing lug nuts on our truck and 5th wheel trailer. I will soon have a 800 watt inverter mounted under the hood of the truck. Hopefully  it will run this without a problem. It will be run off the extra battery in the truck.        Roger
  • MGP59DB said thank you
#6 Reed Breneman OFFLINE
Reed Breneman
  • 1,213 Thanks
  • 461 posts
Posted March 03, 2017 - 01:54 PM
I am considering buying an electric impact I have several 1/2 in air impacts and all are apperently wearing out ,None will remove lug nuts on a car anymore unless  you break them loose first.My 3/8 and 1/4 in impacts work fine for their respective uses and I have all the air pressure and volume in the world(both 50 gallon compressors are tied together and each outlet in the shop has a pressure regulator and there are 6 of those).All other air tools appear to work as they should so I am guessing they are wore out.Oh I have 125 psi available at ea outlet.but it seems strange that all 4 of them chose now not to function well??????They are all mid range priced impacts so there should be some quality and they dont work any better in my shop at home versus my big shop(1- 25 gallon air compresser at home)Any Ideas on what could be wrong or are they just shot???I do oil them regularly.none are more then 7 years old and use is fairly light really
#7 MGP59DB OFFLINE
MGP59DB
  • 1,486 Thanks
  • 710 posts
Posted March 03, 2017 - 02:21 PM
Like I said , My Uncle has the same tool and I have used it - that is what made me realize that for the price ($39.00 w/ coupon) I could afford to have one around the shop . I like it and know I will use it , at that price if it takes a crap in ten years , Meh- big deal.
I don't have much experience with pneumatic impacts , I have used them but couldn't tell you why they might be failing Reed.
  • hamman said thank you
#8 Reed Breneman OFFLINE
Reed Breneman
  • 1,213 Thanks
  • 461 posts
Posted March 03, 2017 - 05:44 PM
I have owned some of the electric ones before ,cheaper ones and more expensive ones ,all were impressive and lasted well I just wore them out or like in my last one somehow I lost it??A friend has a 12 volt one he keeps in his truck and uses for flat tires ,It is awsome!
#9 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 7,104 Thanks
  • 2,319 posts
Posted March 03, 2017 - 05:53 PM
You could have a restriction in the air hose that attaches between the regulator and the air tool - just a thought.  The two worst enemies of air tools is lack of lubrication and dirt and debris in the pressurized air lines feeding them.  Usually if an air tool has no power it is because there is not enough air volume and pressure getting to the tool - you may want to put a pressure gauge at the end of the hose temporarily and see how much pressure is at the end of the hose while the tool is triggered - just a suggestion.
  • Reed Breneman said thank you
#10 MGP59DB OFFLINE
MGP59DB
  • 1,486 Thanks
  • 710 posts
Posted March 04, 2017 - 01:47 PM
Just wanted to mention that I was out playing with the Coleman generator .
Woo Hoo , It runs and it generates :rocker2:
Needs to be tuned and all , but I know it works.
Edited by MGP59DB, March 04, 2017 - 01:48 PM.
#11 MGP59DB OFFLINE
MGP59DB
  • 1,486 Thanks
  • 710 posts
Posted April 01, 2017 - 03:29 PM
I found a great deal on some new/used tires and rims for my truck , So I got to use the new impact wrench the other day .
It sure made quick work of changing all the tires out. I am very pleased with the performance of the tool and glad to have it.
$202 for 4 like new tires and rims :D
I also was out playing with the $49 Generator , started up pretty easy and looks damn good when cleaned .
