Cub 1811 3 point hitch pictures and measurements
cub 1811 3 point hitch
9 replies to this topic
#1 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,796 Thanks
  • 1,060 posts
Posted March 01, 2017 - 10:25 PM
I've been trying to figure out which 3 point hitch I need for my 1811.  It looks like I need the model 383.  I have found some after market kits but they are way out of my budget.  If someone has a factory 3 point for this tractor I would very much appreciate your help.  I need the measurements and pictures for the lift arms, side lift links, and top link.
If anybody has any other ideas or suggestion I would also appreciate them.
Here are pictures of what I currently have.
I bought these pins today.  I figured they will work for the lower arms.
Edited by Mark 149 J., March 02, 2017 - 12:08 AM.
#2 KennyP ONLINE
  • 35,890 Thanks
  • 44,623 posts
Posted March 02, 2017 - 06:20 AM
Mark, you should be able to get the top link at TSC if you have one nearby. Length should be 10-15" +/-. The side lift links can be bought for $55 at Extreme, part # CC-34-002. If someone can get the dimension for the lower arms, you can build them for less than they want for a set.
  • ducky, chieffan and Mark 149 J. have said thanks
#3 chieffan OFFLINE
  • 9,002 Thanks
  • 6,171 posts
Posted March 02, 2017 - 09:10 AM
You have what I started with on my White 1655  (MTD 966)  Got the 4 ball socket's and lift link and went to the welding shop.  this is what I left with, less the draw bar.  3 Point-1.JPG     3 Point-2.JPG   Have about $225 in all together.   I have all the measurements from mine if that will help you any.
  • Mark 149 J. said thank you
#4 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,796 Thanks
  • 1,060 posts
Posted March 02, 2017 - 10:33 AM
Thanks Kenny!
I don't have a TSC near me but did find the top link on Amazon for a good price.  I just looked at the side links that you mentioned.  They look like they should work.  If I can get the dimensions for the lower arms I definently will try and make them myself.
#5 KennyP ONLINE
  • 35,890 Thanks
  • 44,623 posts
Posted March 02, 2017 - 10:35 AM
Those side links are worth the money for what you get.
#6 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,796 Thanks
  • 1,060 posts
Posted March 02, 2017 - 10:36 AM
You have what I started with on my White 1655  (MTD 966)  Got the 4 ball socket's and lift link and went to the welding shop.  this is what I left with, less the draw bar.  attachicon.gif3 Point-1.JPG    attachicon.gif3 Point-2.JPG  Have about $225 in all together.   I have all the measurements from mine if that will help you any.
Thanks Chieffan!
I might take you up on your offer if I can't get the dimensions for a cub.  They do look a lot alike.
#7 KennyP ONLINE
  • 35,890 Thanks
  • 44,623 posts
Posted March 02, 2017 - 10:42 AM
I just found a drawing for the lower arms. I'll post something in a bit.
#8 KennyP ONLINE
  • 35,890 Thanks
  • 44,623 posts
Posted March 02, 2017 - 11:14 AM
See if you can build some from this. Just remember when drilling the 1/2" hole to turn the arm over so you have a left and a right!
#9 Mark 149 J. ONLINE
Mark 149 J.
    Mark J.
  • 1,796 Thanks
  • 1,060 posts
Posted March 02, 2017 - 11:28 AM
That look like it should work.  I'm always amazed by what you find!
Thanks!
#10 KennyP ONLINE
  • 35,890 Thanks
  • 44,623 posts
Posted March 02, 2017 - 11:38 AM
I have my sources! Just takes a little snooping to find things.
Also tagged with one or more of these keywords: cub, 1811, 3 point hitch
