Briggs twin rebuild
briggs twin sleeved seized
5 replies to this topic
#1 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted March 01, 2017 - 09:55 AM
Where can I get an Rebuild kit for this motor? its a briggs twin 16hp 656cc sleeved
Bought tractor for 150  :rocker2:
Edited by Montgomeryluv15, March 01, 2017 - 09:56 AM.
  • Bolens 1000 said thank you
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 01, 2017 - 01:43 PM
I can likely get you anything you would need. but hard to quote any prices until you get in there and see what you need exactly
  • EricR and Montgomeryluv15 have said thanks
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted March 01, 2017 - 10:39 PM
Get a vertical and convert it to horizontal it's an easy job . You need your crank, sump, pto cover, intake, and oil slinger.and you have to drill two oil drain holes in the valve box. And the dip stick hole , some already have it and it's just plugged
#4 DZG OFFLINE
DZG
  • 609 Thanks
  • 525 posts
Posted March 02, 2017 - 09:13 AM
Check out www.mowergraveyard.com, i think they had one listed for 150 bucks that runs
  • Montgomeryluv15 said thank you
#5 Montgomeryluv15 OFFLINE
Montgomeryluv15
  • 47 Thanks
  • 67 posts
Posted March 02, 2017 - 06:23 PM
The engine is a al Horizontal. all th 656cc twin briggs for the MWs where
#6 Tecumseh power OFFLINE
Tecumseh power
  • 1,477 Thanks
  • 1,112 posts
Posted March 02, 2017 - 06:32 PM
I know, I was trying to say you can get a really good vertical cheaper than. You can probably rebuild your horizontal, and you can convert the vertical shaft engine to a horizontal shaft.
