Massey 14 diesel repower
4 replies to this topic
#1 Greasy6020 OFFLINE
Greasy6020
  • 1,473 Thanks
  • 1,397 posts
Posted February 28, 2017 - 02:08 PM
I recently brought home a Massey 14 with a dead/dying kohler k321
I recently found a kubota d722 from a reefer trailer that was put out of service, by a bad compressor for the cooking system. I got it free
I just need to go pick it up.
So, in my double period automotive shop class, I'm gonna set up the Massey and kubota on a hot date.
Anyone have ideas, opinions or concerns?
I know I'm gonna have to figure out where to stick the rad...
  • pryan05 said thank you
#2 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 28, 2017 - 04:30 PM
Well it looks like you picked a good engine for it, it runs the right RPMs 3600 and makes more power than you Kohler 14 does.
http://www.kubota.com.au/product/d722/
Good luck with the project. :thumbs:
  • limebuzz, Greasy6020 and pryan05 have said thanks
#3 pryan05 OFFLINE
pryan05
    LGT
  • 630 Thanks
  • 347 posts
Posted February 28, 2017 - 04:31 PM
I put the rad just in front of the dash on my Ford LGT and used a rad that I bought off of ebay, is for an austin mini.  Just make sure you have the rotation right on the motor.  The Kubotas are great motors and the Mf 14 will be and excellent platform.  Post lots of pictures and ask any questions.  Check out my build in the re-power section.  It should be very similar.   Have fun I will keep an eye on this one!
  • Greasy6020 said thank you
#4 Cvans ONLINE
  • 6,629 Thanks
  • 6,121 posts
Posted February 28, 2017 - 05:35 PM
That engine is probably going to have an over sized oil pan that might be hard to get between the frame rails. As that engine is used in a lot of different applications a regular oil pan should be easy to come by.
Should make you a really nice tractor when your done.
  • Greasy6020 and pryan05 have said thanks
#5 chieffan OFFLINE
  • 10,088 Thanks
  • 6,612 posts
Posted March 01, 2017 - 08:18 AM
Will have to do some machining for an adapter between the engine and drive shaft.   Had one made for friend who did that same thing but a different tractor.  Cost $110 for the material and the machining but would bolt right to the flywheel and drive shaft would slide on a stub with key way on the adapter. .  Should work out well.
